Discuss
Kenmore Dryer doesn't stop running
 in
Dryer Repair
Model # 110 70712990. Dryer continues to run through all the timer cycles. I set timer for 20 minuets, timer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer doesn't stop running
  #1 (permalink)
Old 08-15-2009, 09:39 AM
Junior Member
Jimmy-bow is on a distinguished road
Default Kenmore Dryer doesn't stop running
Model Number: 110 70712990   Brand: Kenmore   Age: 1 - 5 years
Model # 110 70712990. Dryer continues to run through all the timer cycles. I set timer for 20 minuets, timer advances and dries clothes, timer advances to off, dryer turns off, timer continues to advance through off position, timer advances and the dryer turns back on, runs through next cycle, turns off, timer advances again, dryer turns back on. The dryer stops when the door is opened or the dryer is unplugged.
Any help
thanks
-Jim
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
  #2 (permalink)
Old 08-16-2009, 12:04 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well, it should not do that.
Sounds like a bad timer, here is the part.
Part number: AP3100523
Good luck,
__________________
  #3 (permalink)
Old 08-16-2009, 03:46 PM
Junior Member
Default Re-Kenmore Dyer doesn’t stop running
Thanks for the reply.
How can I test the timer to be sure it’s bad before I pony-up the $90.00?
-Jim
  #4 (permalink)
Old 08-16-2009, 04:07 PM
Senior Expert
APP Volunteer
Default
Unfortunately there is no good way to do that, you sorta arrive at the timer by a process of elimination, in this case there is not another likely candidate.
If your timer is doing this in all cycles it is highly likely the timer is the problem, but the only way to be certain is to replace it and see if that cures the problem.
__________________
  #5 (permalink)
Old 08-16-2009, 04:42 PM
Junior Member
Default Re- Kenmore Dryer doesn't stop running
Okay I’ll just replace the timer. The part number on the timer is PN: 3976577 which matches the one called out at Sears Parts Direct. Com. But your attached PN is different. Should I care? And do you get compensated if I order form Appliance Parts Pros?
-Jim
  #6 (permalink)
Old 08-16-2009, 05:25 PM
Senior Expert
APP Volunteer
Default
Hi Jim
The part number shown in the picture is an Appliance Parts Pro part number, but the part should be the same. You can confirm this by going to the Find Parts section of this Forum and checking the part by the number from SearsParts and the part shown in the picture will come up.
We are volunteers and do not get compensated in any way by the APP company. They put up the web site to help folks (and I imagine to also generate some business) and we (or at least I) volunteer to answer questions for the challenge of trying diagnose a problem wihtout actually seeing the machine in operation. Plus it also hones diagnostic skills for repairing appliances. It sorta allows us to have the fun of fixing the machine (diagnosing) without having to get all dirty and twisted by having to do the actual work.
So, we can also say go where the part is the least expensive, which in your case looks lik Sears, but check whether or not there is sales tax in your case and also the shipping charges to get a full comparison. One thing you will find from APP is that delivery is very, very fast.
Good luck, let us know if a new timer fixes things.
__________________
  #7 (permalink)
Old 08-16-2009, 05:33 PM
Junior Member
Default
Wow that’s nice of you to help. I’ll order the timer and let you know if it resolves the problem.
Thanks again
-Jim
  #8 (permalink)
Old 08-19-2009, 06:37 PM
Junior Member
Default
The new timer didn’t fix the problem. The timer continues to advance until the dryer turns off and then back on again.
-Jim
  #9 (permalink)
Old 08-20-2009, 01:55 PM
Senior Expert
APP Volunteer
Default
Jim
I am both somewhat amazed and completely apologetic. Unforturnately using a Forum like this for repair involves what economists term tradeoffs. If you have a service tech visit, you will get your machine repaired, but at a cost of $150.00 to $250.00 in your situation. If you get a recommendation from a Forum you will spend a lot less, but there is not a guarantee your machine will get repaired. We may not have the correct diagnosis, you may not put the part in correctly, or the replacement part may be defective.
In this case I don't think you put the part in incorrectly, and I doubt if the replacement part was defective. That leaves us with an incorrect diagnosis for which I apologize and I am sorry you spent the funds unnecessarily.
That being said, we still have your dryer to fix. I am thinking you may have two problems, a short in the wiring to the timer motor and a bad push to start switch. The way your dryer timer works is that there is a small motor in the timer that is powered by electricity. When you engage the timer the motor powers up and turns the timer gears which go through various sets of electrical contacts and operate your dryer according to plan. When the dryer gets to the off position, the circuit is broken and electricity no longer goes to the timer motor and the timer stops advancing.
Obviously in your case the timer motor in the timer is continuing to get electricity even after the dryer reaches the off position. This suggests that the problem is in the wiring to the timer motor, but that wiring comes through the timer, which is why the first thoughts are that the timer was bad. Well,unless the second timer is bad you somehow have power getting to the timer motor independent of the timer, and you are just going to have to trace that wiring to find out how that is happening.
Now the second problem is that after your timer advances to the next cycle the dryer comes on. This definitely should not happen, because even if the timer advances to a start position, the dryer will not come on unless the push to start switch is pushed, which is not happening. Now the way your push to start switch works is kinda interesting. When you engage the push to start switch, electrical current working through a coil inside the switch keeps it closed even after your release the start knob and it returns to its rest position. When current stops going to the start switch, the electricity through the coil stops and a spring makes the switch disengage. This is why your dryer stops when the timer gets to the off position.
Now obviously the push to start switch is remaining engaged, so that when the timer gets to the new cycle the dryer turns on. This suggests either a bad push to start switch, or problems in the wiring between the varous components and the push to start switch.
Therefore I suggest you replace the push to start switch, as it is an inexpensive item and replacing it will take it out of the equation. If that fixes the problem, great, if not you are going to have to trouble shoot your wiring starting from when it comes into the dryer from the outlet.
Well, I hope this helps, and I wanted to explain what is going on as much as possible so you would understand why the timer was suggested and the rationale for the next steps.
Good luck, let us know what you find out.
__________________
  #10 (permalink)
Old 08-20-2009, 02:51 PM
Junior Member
Default
Yeah what I disappointment… I thought I was going to be the hero last night, but I was still just a zero.
I’ll get the switch tonight, and write you back when I’m done crying.
-Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer won't stop running jasond Dryer Repair 4 09-27-2009 04:19 AM
Dryer stop running superglide31 Dryer Repair 11 03-12-2009 08:11 AM
dryer won't stop running! raycharn Dryer Repair 2 11-25-2008 06:37 AM
Dryer won't stop running manderson Dryer Repair 0 08-04-2008 06:46 AM
Whirlpool dryer won't stop running dryrprob Dryer Repair 5 11-04-2007 02:38 AM
