Discuss
roper dryer no heat
 in
Dryer Repair
Heating element is not turning on. Checked for power and it all seems good from all of the terminals.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » roper dryer no heat
  #1 (permalink)
Old 01-15-2008, 04:20 AM
sgrimes9 sgrimes9 is offline
Junior Member
sgrimes9 is on a distinguished road
Post roper dryer no heat
Model Number: rex4635eq1   Brand: Roper   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 07:56 AM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
IF there is 240 volts going to the dryer it sounds like it,s your heating element.Go to the back of the dryer pull the plug and remove the back panel.You will see the element housing on the lower right side remove the screw and take out the element to see if there is a break in the coil,if so replace element.
__________________
  #3 (permalink)
Old 01-16-2008, 02:55 AM
Junior Member
Default no break in heating coil
Doesn't seem to have any breaks in the heating element. Could it be one of the operating thermostats?
  #4 (permalink)
Old 01-16-2008, 08:45 AM
Senior Expert
APP Volunteer
Default
It could be, do you have a multimeter if so check for continuity on the thermostats, they should not be open . If there ok put everything back in place and try the dryer on the heat cycle.While running grab the timer knob and try moving the knob up and down lightly hold it in the position for a minute or two then check to see if there is heat in the drum.If so replace timer.
__________________
  #5 (permalink)
Old 01-18-2008, 05:35 AM
Junior Member
Default
That doesn't affect it at all. Does open mean that it doesnt make the cuircut?
  #6 (permalink)
Old 01-18-2008, 06:28 AM
Senior Expert
APP Volunteer
Default
yes You could jump each part with a heavey peice of wire .Remove the wires from each thermostat ,one at a time, jump each one checking to see if there,s heat. THIS IS ONLY A TEST, DON,T LEAVE A THERMOSTAT JUMPED AND USE THE DRYER If you find the dryer working after you jumped a thermostat,Relace that thermostat.USE CAUTION WHEN CHECKING ELECTRICITY..
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper dryer with no heat aaronii Dryer Repair 2 04-18-2008 07:33 AM
Roper Gas Dryer not heating Brian K Dryer Repair 3 01-15-2008 12:33 PM
roper dryer no go joeyrat Dryer Repair 0 01-12-2008 04:15 PM
Roper Dryer will not run TERRY38108 Dryer Repair 1 11-07-2007 05:21 PM
roper gas dryer spins but no heat relvis Dryer Repair 1 09-19-2007 10:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
