Discuss
GE Dryer Buzzing Instead of Starting
 in
Dryer Repair
My dryer recently stopped working. When I tried turning it on, it would just make a buzzing sound. The drum
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Dryer Buzzing Instead of Starting
  #1 (permalink)
Old 01-14-2008, 08:02 PM
gumbo2000 gumbo2000 is offline
Junior Member
gumbo2000 is on a distinguished road
Default GE Dryer Buzzing Instead of Starting
Model Number: 473   Brand: GE   Age: 5 - 10 years
My dryer recently stopped working. When I tried turning it on, it would just make a buzzing sound. The drum would not spin. I checked the breaker and the lint trap which looked fine.
In an attempt to try to narrow down the problem, I had my wife press in the door switch, gave the drum a spin by hand, and hit the start button. The dryer started and continued to run until my wife let go of the button.
The dryer now seems to be working fine. It will start just as before (without spinning it by hand). It looks to be heating up fine and we've opened/closed the door and restarted it several times.
Any thoughts as to what the problem might have been? Should I keep an eye out for something to fail in the near future?
In case it matters, I will also add that I replaced the belt, drum slides, drum bearing, and heating element back in April, 2007.
Thanks in advance for your help!
Bob
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-14-2008, 08:18 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
The newer GE dryer motors are common for lint build up in the motor at the motor switch. If you get the dryer apart again use a vacuum and small paint brush or compressed air and blow out the motor. Make sure you clean your external vent frequently and do not use flexible vinyl ducting.
Hope this helps and there is no need to replace the motor anytime soon.
  #3 (permalink)
Old 01-15-2008, 08:33 PM
Junior Member
Default
Thank you very much for the fast reply! I will say that we don't clean the external vent as often as we should so I will keep a better eye on that. I'll also give it a good cleaning. Even without, it dried another load tonight.
Thanks again for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DW not draining/starting fakhar11 Dishwasher Repair 0 01-09-2008 01:15 PM
Dishwasher not starting ericeberry Dishwasher Repair 1 01-07-2008 06:51 PM
dryer makes loud buzzing noise won't tumble maureen Dryer Repair 3 12-28-2007 11:08 PM
problem starting self cleaning process tsanford Oven Repair (including Ranges and Cooktops) 0 11-10-2007 10:25 PM
Kenmore dryer sounds like starting, doesn't Lynnarie Dryer Repair 0 10-15-2007 11:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
