Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   dryer igniter will not glow (http://forum.appliancepartspros.com/dryer-repair/438978-dryer-igniter-will-not-glow.html)
hrdrockmom 03-13-2012 01:30 PM
when i start my dryer everything works but the igniter, so I replaced the igniter and it still will not glow, the dryer used to make a loud click when the igniter would glow, light the burner then click again when the burner lit but it does not make the click sound anymore.
ApplianceJunk 03-13-2012 04:25 PM
I would use a multimeter and check the thermal fuse for continuity.
hrdrockmom 03-14-2012 11:10 AM
turns out that the thermal fuse was open, causing the problem. Thank you:)
