I started to notice that my clothes weren't getting dry. They would be slightly warm, but would never dry. I tested every thermostat, sensor, etc that I could with my ohm meter and they all test normal (tested with wires pulled off, but still in dryer). Replaced the gas coils...no change. I turned the dryer on briefly with the door open to watch the burner. It fires up and will run fine with the door off. I placed the door back on and the burner fires up, runs for about 15 seconds, and then shuts off. It will fire up again in about 30 seconds, run for a little over 10 seconds before shutting off. As it cycles, the length between firing increases. Replaced the cycling thermostat (even though it tested normal)...no change. Any ideas? Do the thermostats, fuses, etc have to be removed from the dryer for accurate testing?
Groups: APP Team
Hello.
If you remove the vent hose from the back of the dryer and run it with normal load does it make any difference?
Post the result.
I haven't done that yet, but I did check where the vent exits the house and seemed to have good air flow coming out.
Groups: APP Team
Hi.
Please run the test I suggested above and let me know the results.
Thank you.
I removed the vent hose and it dried! Now what? Thanks!
Groups: APP Team
Hello.
The next step is cleaning the vent entirely.
Check the hose between the dryer and wall inlet first. Illuminate any kinks in it, then if it's venting through the wall right behind the dryer clean it yourself. If the vent is long and goes who knows where - call the professional duct cleaning company in you area.
Thank you and good luck.
