| » kenmore dryer wont start |
Model Number: 11066962500 Brand: Kenmore Age: 5 - 10 years
my dryer is acting up and it does not want to start every once in a while so i took it apart and checked out the start switch and the thermal fuse and the door switch they all check out fine whatelse could be causing this?
Hi.
Unfortunately it's very hard to proper diagnose the "every once in the while problem". To run the test the dryer has to be "down". The most common problem could be the motor or the timer. Also the door switch may have intermittent problem. Guessing is expensive. Next time try to push and release the door switch several times, see if it helps. The defective belt switch definitely will cause the problem. Is there anything you do that makes the dryer start? Please post results.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 03-12-2012 at 12:35 PM. |
also wherE will i find the motor switch ?
Hi.
The belt switch located at the rear motor mounting bracket. To test the door switch - locate the single wire on one side - common wire (marked C) and with door closed you should have continuity between C and NO. Open the door - continuity between C and NC. The belt switch Part number: 279782 The door switch Part number: AP3132865 Post the results.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 03-12-2012 at 02:58 PM. |
Near the motor and idler:
Small white switch with a yellow wire going to it: http://1.bp.blogspot.com/-va6qJgmVX7.../s1600/030.jpg |
Hallerween day I fixed one of these type dryers and made a few photos:
ApplianceJunk.com Blogspot: Kenmore 4-wheel drive dryer de-mystified! |
Hello.
Please describe how did you do the tests.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Kenmore Dryer wont start | bonseye44 | Dryer Repair | 0 | 05-20-2011 06:55 AM |
| kenmore he 4 dryer wont start | jilldale | Dryer Repair | 1 | 04-29-2011 01:58 AM |
| My kenmore dryer wont start | Mike Swanson | Dryer Repair | 1 | 03-11-2010 11:25 AM |
| kenmore dryer wont start | MOUSENUP | Dryer Repair | 1 | 09-07-2009 07:47 AM |
| Kenmore Dryer wont start | rrhoward78 | Dryer Repair | 2 | 02-01-2009 12:05 PM |
