Discuss
Is motor supposed to turn freely?
 in
Dryer Repair
To try to understand motor movement to figure out why the dryer is noisy, I isolated the motor and it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Is motor supposed to turn freely?
  #1 (permalink)
Old 01-13-2008, 09:37 PM
ameyring ameyring is offline
Junior Member
ameyring is on a distinguished road
Default Is motor supposed to turn freely?
Model Number: S58NXMKE-6674   Brand: Whirlpool   Age: More than 10 years
To try to understand motor movement to figure out why the dryer is noisy, I isolated the motor and it doesn't run, just hums when power is applied. With power disconnected, I can't turn the shaft. Is the shaft supposed to be loose enough to be turned with my fingers?
Could humming also come from a defective electronic board?
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-14-2008, 04:55 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Maybe you dropped a screw in the motor, it was running before! If ok, your motor bearings are bad. Motor shaft should turn and have no lateral play. If so, just order a new one.
__________________
  #3 (permalink)
Old 01-14-2008, 01:16 PM
rsuch rsuch is offline
Junior Member
rsuch is on a distinguished road
Default
Yes, it should turn freely, especially if the belt is removed. It is apparently bound up, which would also cause a humming sound when applying power to it.
  #4 (permalink)
Old 01-18-2008, 11:15 PM
Junior Member
Default Follow-up question
Thanks for replying to my question. On a whim, I tested the motor while isolated and it seemed to run great. Perhaps something was stuck in there before or there was too much lint (I vacuumed the motor). Thus, I reinstalled the motor, testing it now and then with no problem. After dryer was put back together, motor returned to a humming state and eventually quit. After a few minutes, I could restart it, but then it would quit again. Is this the sign of a tired motor in need of replacement or could there be too much stress somewhere.
Thanks!
  #5 (permalink)
Old 01-19-2008, 02:40 AM
Senior Expert
APP Volunteer
Default
You have a bad motor, shaft should turn with almost no friction, like skating on wet ice.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spin cycle either 'weak' , motor runs & tub doesn't turn or ... sfw1960 Washer Repair 10 11-26-2007 01:00 PM
Oven won't turn on jdayseidel Oven Repair (including Ranges and Cooktops) 4 11-21-2007 05:59 PM
Whirlpool belt-drive won't spin when it's supposed to Lmarks Washer Repair 13 10-03-2007 05:41 PM
Oven will not turn off daugherr Oven Repair (including Ranges and Cooktops) 0 08-23-2007 05:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
