Discuss
Kenmore 70 series - No heat, won't shut off
 in
Dryer Repair
Dryer's timer dial DOES MOVE on timed cycle...but will not shut off (it will shut off if I manually move
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 70 series - No heat, won't shut off
  #1 (permalink)
Old 08-10-2009, 04:28 PM
Junior Member
c1eddy is on a distinguished road
Default Kenmore 70 series - No heat, won't shut off
Model Number: 110.60722990   Brand: Kenmore   Age: 1 - 5 years
Dryer's timer dial DOES MOVE on timed cycle...but will not shut off (it will shut off if I manually move the dial to "off"). I have not even tried it in "Automatic", as we never use this mode. This issue seems to have happened at roughly the same time that the heat in the dryer quit working (a couple days ago).
I was going to order a new timer...but thought I would run it by some folks more knowledgeable than me before I do.
Here is a link to the parts page (links in blue on the left side), if that helps:http://www.********************************.com/partsdirect/getModel!retrieve.pd?modelNumber=11060722990
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 08-12-2009, 08:05 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Can you clairify a few points.
You say the timer moves but to shut off the machine you have to manually move timer to off. What happens if you do not move it, does it go to off and stop, but not shut off the machine? Does it go past off?
When the heat failed what did you do to fix that?
I think the timer is likely the problem and replacing it might solve your problem, but if you want more info let us know the answers to the above, and also operate the machine on auto just to see what happens and let us know those results also.
__________________
  #3 (permalink)
Old 08-14-2009, 03:39 AM
Junior Member
Default
I'll do it and post back. Thanks.
  #4 (permalink)
Old 08-14-2009, 11:16 PM
Junior Member
Default
Ok...after a little further investigation:
The timer dial does move toward off, as I said initially, but seems to stop moving just ahead of the off position. It will only shut off when I manually move it forward to off...or open the door.
In the auto mode, the dial does not move and it does not shut off until I manually move it to the off position or open the door. I put a damp towel in tonite and it ran till the towel was dry...but dial never moved and it did not shut off.
I still have not addressed the heat issue. Still no heat.
  #5 (permalink)
Old 08-15-2009, 01:39 PM
Senior Expert
APP Volunteer
Default
Ok, well it sounds like the timer so if you want to try and fix this I suggest you go ahead and replace it and see if that fixes the timer movement problem . You should check continuity on the thermal fuses and thermostats to see if that is the source of the heat problem, and also ohm out and check the heating element. If you find the problem in them, replace the faulty part at the same time as the heater. If they all check out, see if the new timer will fix both problems.
Do Let us know what happens.
__________________
  #6 (permalink)
Old 08-20-2009, 08:38 PM
Junior Member
Default
Heating element was bad...so ordered a timer and heating element. Installed the timer tonite. No change: advances toward the "off" when in timer mode, but stops advancing just ahead of it...and just keeps on running. Any ideas?
Heating element will be here in couple days.
  #7 (permalink)
Old 08-21-2009, 06:06 AM
Senior Expert
APP Volunteer
Default
Let's see what happens when you put in the new heating element. Try it after that and see how the machine performs. Replacing the element will reduce the number of things contributing to the problem.
Let us know what you have then. Thanks
__________________
  #8 (permalink)
Old 08-30-2009, 12:57 AM
Junior Member
Default
Replaced the heat element...and now everything works fine. So...put the old timer back in and dryer continued to work perfectly well. The outfit I bought the new timer from was willing to take it back. I'm not sure why the problem of not shutting down...while on the timer rather than auto ...was remedied by replacing bad heat element. Thanks very much for the help you have offered, sidfink43. When you have time...can you give a brief explanation of what might have been going on?
  #9 (permalink)
Old 08-30-2009, 06:37 AM
Senior Expert
APP Volunteer
Default
Well, glad the new heating element fixed it, and that you were able to return the timer.
Here's what I think was going on.
In auto mode the timer will not advance when the heating element is on. This is how it attempts to set the drying time to match the time needed to dry the clothes.
The thermostat cycles the heating element on and off, and off and turns it off when it reaches a certain temperature, at which time the timer will then advance until the heating element comes back on. Since the element was not heating (the machine did not know this, it thought it was heating), the dryer never reached a temperature for the thermostat to cycle off the heating element, so the thermostat never turned the element off so the timer never advanced.
In timed mode the timer moves independent of the hearing cycle. It sounds like the timer reached the cool down section and then stopped because of the problem with the heating element.
Thanks for updating us. Good luck going forward with your machine.
__________________
  #10 (permalink)
Old 03-12-2010, 06:39 AM
Junior Member
abengoa is on a distinguished road
Default Same problem
I have the same problem! Can you tell me what the part number for the heat element. Also was it easy to replace! Is there a link to instruction on how this was done.
THe model # for my dryer :11076712694 which is also the Kenmore 70 series.
Thanks for any help that can be offered.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 80 series dryer won't heat Dhodge Dryer Repair 1 11-11-2009 09:12 PM
dryer will heat but not spin- kenmore 70 series model abengoa Dryer Repair 1 09-14-2009 08:54 PM
Kenmore 70 series W/D, how old? resloan Washer Repair 2 07-28-2009 12:54 PM
kenmore 80 series broken heart Washer Repair 1 02-23-2009 05:38 PM
Kenmore 60 Series(gas) Runs but wont heat PJM Dryer Repair 0 02-02-2008 06:09 AM
