prn1955
#1 Posted : Monday, August 10, 2009 1:39:16 AM(UTC)
prn1955
I started to replace the drum bearings, the old ones were totally wore off. How are the bearrings positioned, short side toward the door or away from it. Thanks
sidfink43
#2 Posted : Wednesday, August 12, 2009 6:12:43 AM(UTC)
sidfink43
Here is the service manual which will explain how to position them.
http://www.servicematters.com/m...ibrary/docs/16008714.pdf
Good luck
Whirlpool WTW5800BW0 drum bearings? (Washer Repair)
by edw00app 5/23/2023 2:02:04 PM(UTC)
rear drum bearing (Dryer Repair)
by hitmehhh 10/7/2016 3:56:44 AM(UTC)
rear drum bearing (Washer Repair)
by mamageer 12/13/2013 11:58:19 AM(UTC)
changing drum bearing on lg tromm (Washer Repair)
by tfd703 8/19/2013 7:30:58 PM(UTC)
Increasingly Loud GE Dryer - Is a complete Rear Drum Bearing Kit (or more) required? (Dryer Repair)
by Matthew W. 1/21/2013 1:26:02 AM(UTC)
Drum Bearing slide order of installation (Dryer Repair)
by cbishodr 4/13/2012 9:33:24 AM(UTC)
Replacing drum bearings (Washer Repair)
by nagihs 8/8/2011 6:46:42 PM(UTC)
Clothes get hung between drum and front drum bearing (Dryer Repair)
by jackpeg 7/29/2011 10:24:05 AM(UTC)
GE Front Drum Bearing (Dryer Repair)
by Hokiefan 5/5/2011 8:45:13 AM(UTC)
Hotpoint drum bearing glides (Dryer Repair)
by RCoile 2/18/2011 9:46:47 AM(UTC)
Replacing Drum Bearing (Dryer Repair)
by jburski 1/4/2011 12:31:40 PM(UTC)
Front Drum Bearing/Glides (Dryer Repair)
by jrotella 4/18/2010 5:35:29 AM(UTC)
GE dryer drum bearing glides (Dryer Repair)
by kevin ulmer 2/24/2010 2:40:34 PM(UTC)
Dryer Front Drum Bearing Glides (Dryer Repair)
by Robert70 1/24/2010 7:10:32 AM(UTC)
dryer squeals suspect drum bearing (Dryer Repair)
by premech1 10/10/2009 10:22:39 AM(UTC)
