Hello today my dryer stopped spinning. I checked the belt and the door switch and both are good. Im not sure if there is anything else that it could be except the motor. Any and all help is appreciated. Thank you
Hi. I get more info about the dryer. I checked the heat limit switch and it was open so I jumped it and the dryer heated and turned just fine. Now the problem is that it heats all the time with out pressing the start button. I checked the button for resistance and it is working fine. Any help is great. Thank you.
