Discuss
How do I tell if the Bearing is bad
 in
Dryer Repair
I had problems with my dryer's drum not turning. I went ahead and took the drum out through the front
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How do I tell if the Bearing is bad
  #1 (permalink)
Old 08-08-2009, 11:56 AM
Junior Member
VickiS is on a distinguished road
Default How do I tell if the Bearing is bad
Model Number: FEX831CS0   Brand: Frigidaire   Age: 1 - 5 years
I had problems with my dryer's drum not turning. I went ahead and took the drum out through the front and literally have taken the whole dryer apart. I took the bearing out as that seems to be the culprit. How do I tell if it's bad and how much will it cost to get a new one to replace it?
Thanks!
Related Models
Frigidaire FEX831CS0 Frigidaire/laundry Center
Frigidaire FEX831FS0 Frigidaire/laundry Center
Frigidaire FEX831FS1 LAUNDRY CENTER
Frigidaire FEX831FS2 LAUNDRY CENTER
Frigidaire FEX831FS4 LAUNDRY CENTER
Frigidaire FEZ831AS0 Lc - Frigidaire
Frigidaire FEZ831AS1 Lc - Frigidaire
Frigidaire FEZ831AS2 Frigidaire/laundry Center
Frigidaire FEZ831CFS0 Frigidaire/laundry Center
Frigidaire FEZ831CFS1 LAUNDRY CENTER
Amana FF105 REF - BOTTOM MOUNTS
Amana FF105A REF - BOTTOM MOUNTS
Amana FF105B REF - BOTTOM MOUNTS
Amana FF105L REF - BOTTOM MOUNTS
Amana FF105LA REF - BOTTOM MOUNTS
Amana FF105LB REF - BOTTOM MOUNTS
Amana FF125 REF - BOTTOM MOUNTS
Amana FF125A REF - BOTTOM MOUNTS
Amana FF125B REF - BOTTOM MOUNTS
Amana FF125L REF - BOTTOM MOUNTS
Amana FF125LA REF - BOTTOM MOUNTS
Amana FF125LB REF - BOTTOM MOUNTS
Amana FF15 FREEZER- VERTICAL
General Electric FF16DSARWH Refrigerator
General Electric FF16DSBRWH Refrigerator
General Electric FF16DSCRWH Refrigerator
General Electric FF16DSDRWH Refrigerator
General Electric FF16DSERWH Refrigerator
General Electric FF16DXARWH Refrigerator
General Electric FF16DXBRWH Refrigerator
General Electric FF16DXCRWH Refrigerator
General Electric FF20DSARWH Refrigerator
General Electric FF20DSBRWH Refrigerator
General Electric FF20DSCRWH Refrigerator
General Electric FF20DSDRWH Refrigerator
General Electric FF20DSERWH Freezers
General Electric FF20DXARWH Refrigerator
General Electric FF20DXBRWH Refrigerator
General Electric FF20DXCRWH Refrigerator
Amana FF98 REF - BOTTOM MOUNTS
Amana FF98A REF - BOTTOM MOUNTS
Amana FF98B REF - BOTTOM MOUNTS
Amana FF98L REF - BOTTOM MOUNTS
Amana FF98LA REF - BOTTOM MOUNTS
Amana FF98LB REF - BOTTOM MOUNTS
Frigidaire FFBD1821MB0A DISHWASHER
Frigidaire FFBD1821MS0A DISHWASHER
Frigidaire FFBD1821MW0A DISHWASHER
Frigidaire FFBD2403LB0A DISHWASHER
Frigidaire FFBD2403LB0B DISHWASHER
Frigidaire FFBD2403LS0B DISHWASHER
Frigidaire FFBD2403LW0A DISHWASHER
Frigidaire FFBD2403LW0B DISHWASHER
Frigidaire FFBD2405KB0 DISHWASHER
Frigidaire FFBD2405KB0A DISHWASHER
Frigidaire FFBD2405KS0 DISHWASHER
Frigidaire FFBD2405KS0A DISHWASHER
Frigidaire FFBD2405KW0 DISHWASHER
Frigidaire FFBD2405KW0A DISHWASHER
Frigidaire FFBD2407LB0A DISHWASHER
Frigidaire FFBD2407LB0B DISHWASHER
Frigidaire FFBD2407LM0A DISHWASHER
Frigidaire FFBD2407LM0B DISHWASHER
Frigidaire FFBD2407LQ0A DISHWASHER
Frigidaire FFBD2407LQ0B DISHWASHER
Frigidaire FFBD2407LS0A DISHWASHER
Frigidaire FFBD2407LS0B DISHWASHER
Frigidaire FFBD2407LW0A DISHWASHER
Frigidaire FFBD2407LW0B DISHWASHER
Frigidaire FFBD2409LB0A DISHWASHER
Frigidaire FFBD2409LM0A DISHWASHER
Frigidaire FFBD2409LQ0A DISHWASHER
Frigidaire FFBD2409LS0A DISHWASHER
Frigidaire FFBD2409LW0A DISHWASHER
Frigidaire FFC04M0AW1 Frigidaire/freezer
Frigidaire FFC0513D Frigidaire/freezer
Frigidaire FFC0522DW0 Frigidaire/freezer
Frigidaire FFC0522DW1 Frigidaire/freezer
Frigidaire FFC0522DW10 FREEZER
Frigidaire FFC0522DW11 FREEZER
Frigidaire FFC0522DW12 FREEZER
Frigidaire FFC0522DW13 FREEZER
Frigidaire FFC0522DW14 FREEZER
Frigidaire FFC0522DW15 FREEZER
Frigidaire FFC0522DW16 FREEZER
Frigidaire FFC0522DW17 FREEZER
Frigidaire FFC0522DW18 FREEZER
Frigidaire FFC0522DW19 FREEZER
Frigidaire FFC0522DW2 Frigidaire/freezer
Frigidaire FFC0522DW20 FREEZER
Frigidaire FFC0522DW3 Frigidaire/freezer
Frigidaire FFC0522DW4 Frigidaire/freezer
Frigidaire FFC0522DW5 Frigidaire/freezer
Frigidaire FFC0522DW6 Frigidaire/freezer
Frigidaire FFC0522DW7 FREEZER
Frigidaire FFC0522DW8 FREEZER
Frigidaire FFC0522DW9 FREEZER
Frigidaire FFC0522FW0 Frigidaire/freezer
Frigidaire FFC0522FW1 FREEZER
Frigidaire FFC0522FW2 FREEZER
Frigidaire FFC0522FW3 FREEZER
Frigidaire FFC0522FW4 FREEZER
Frigidaire FFC0522FW5 FREEZER
Frigidaire FFC0522FW6 FREEZER
Frigidaire FFC0522FW7 FREEZER
Frigidaire FFC0522FW8 FREEZER
Frigidaire FFC0522FW9 FREEZER
Frigidaire FFC0522GB0 Frigidaire/freezer
Frigidaire FFC0522GB1 FREEZER
Frigidaire FFC0522GB5 FREEZER
Frigidaire FFC0523DW0 Frigidaire/freezer
Frigidaire FFC0523DW1 Frigidaire/freezer
Frigidaire FFC05C2AW0 Frigidaire/freezer
Frigidaire FFC05C2AW1 Frigidaire/freezer
Frigidaire FFC05C3CW0 Frigidaire/freezer
Frigidaire FFC05C3CW1 Frigidaire/freezer
Frigidaire FFC05C3CW2 Frigidaire/freezer
Frigidaire FFC05C3CW3 Frigidaire/freezer
Frigidaire FFC05C4CW0 Frigidaire/freezer
Frigidaire FFC05K0AW0 Frigidaire/freezer
  #2 (permalink)
Old 08-09-2009, 07:12 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Vicki
If the motor and belt are ok, the rear bearing assembly is probably the culprit. Now that you have done the hard work by taking things apart, replacing it is fairly easy and inexpensive.
Here is the part
Part number: AP2142648
Good luck!
__________________
  #3 (permalink)
Old 08-12-2009, 04:28 PM
Junior Member
Default Ready to install the bearing
Sid,
Thanks for your advice. I received the new dryer bearing today and want to put it back together but there are no instructions with it.... Can you help?
  #4 (permalink)
Old 08-12-2009, 04:39 PM
Senior Expert
APP Volunteer
Default
I can do even better than help.
Here is the service manual which will show you how to do it.
http://frigidaireservicetips.com/pdfs/488_3.pdf
Good luck.
__________________
  #5 (permalink)
Old 08-14-2009, 07:03 AM
Junior Member
Default Thank You
Thank you for all your help! With the tips you gave me here I was able to put my dryer back together and it works great. I never would have thought I could do it. I really appreciate all your help from ordering the right parts, to providing the service manual.
Vicki S.
  #6 (permalink)
Old 08-14-2009, 08:24 AM
Senior Expert
APP Volunteer
Default
Great, glad you were able to do it.
Be sure to tell everyone (except those who might ask you to repair their machines).
Thanks also for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bad tub bearing richappy Washer Repair 3 08-12-2009 08:38 AM
bearing kit the pit Washer Repair 2 07-15-2009 08:53 PM
Possible bad bearing porgas Washer Repair 1 06-24-2009 10:44 AM
which bearing? RoseGin Dryer Repair 0 04-04-2009 03:51 PM
Bearing DANALVIN Washer Repair 0 12-27-2008 10:52 AM
