Discuss
Maytag Dryer Repair
 in
Dryer Repair
I know that the belt needs replaced on the dryer. It was broken and laying in the bottom of the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer Repair
  #1 (permalink)
Old 03-08-2012, 12:53 PM
Junior Member
debmur is on a distinguished road
Default Maytag Dryer Repair
Model Number: LDE8704ACM   Brand: Maytag   Age: More than 10 years
I know that the belt needs replaced on the dryer. It was broken and laying in the bottom of the machine. After taking off the case and removing the drum, I discovered that one of the drum support rollers was laying on the bottom of the machine. Is it possible for the dryer to have been operating with only one drum support roller? Also, how can I tell if the drum support rollers need to be replaced?
Ads By Google
Related Models
Maytag LDE8704ACM DRYER- ELE
Maytag LDE8706ACE DRYER- ELE
Maytag LDE8706ACM DRYER- ELE
Maytag LDE8706ADE DRYER- ELE
Maytag LDE8804ACE DRYER- ELE
Maytag LDE8804ACL DRYER- ELE
Maytag LDE8804ACM DRYER- ELE
Maytag LDE8804ADE DRYER- ELE
Maytag LDE882 DRYER- ELE
Maytag LDE8824ACE DRYER- ELE
Maytag LDE8824ACL DRYER- ELE
Maytag LDE8824ACM DRYER- ELE
Maytag LDE8824ADE DRYER- ELE
Maytag LDE8904ACE DRYER- ELE
Maytag LDE8904ACL DRYER- ELE
Maytag LDE8904ACM DRYER- ELE
Norge LDE9127A DRYER- ELE
Norge LDE9127H DRYER- ELE
Norge LDE9127W DRYER- ELE
Maytag LDE9206ACE DRYER- ELE
Maytag LDE9206ACM DRYER- ELE
Maytag LDE9206ADE DRYER- ELE
Maytag LDE9304ACE DRYER- ELE
Maytag LDE9304ACL DRYER- ELE
Maytag LDE9304ACM DRYER- ELE
Maytag LDE9304ADE DRYER- ELE
Maytag LDE9304ADL DRYER- ELE
Maytag LDE9304ADM DRYER- ELE
Maytag LDE9304AEE DRYER- ELE
Maytag LDE9306ACE DRYER- ELE
Maytag LDE9306ACM DRYER- ELE
Maytag LDE9306ADE DRYER- ELE
Maytag LDE9306ADM DRYER- ELE
Maytag LDE9306AEE DRYER- ELE
Maytag LDE9314ACE DRYER- ELE
Maytag LDE9314ACL DRYER- ELE
Maytag LDE9314ACM DRYER- ELE
Maytag LDE9314ADE DRYER- ELE
Maytag LDE9316ACE DRYER- ELE
Maytag LDE9316ACM DRYER- ELE
Maytag LDE9316ADE DRYER- ELE
Maytag LDE9334ACE DRYER- ELE
Maytag LDE9334ACL DRYER- ELE
Maytag LDE9334ACM DRYER- ELE
Maytag LDE9334ADE DRYER- ELE
Maytag LDE9606ACE DRYER- ELE
Maytag LDE9606ACM DRYER- ELE
Maytag LDE9606ADE DRYER- ELE
Maytag LDE9606ADM DRYER- ELE
Maytag LDE9606AEE DRYER- ELE
Maytag LDE9700 DRYER- ELE
Maytag LDE9700ACL DRYER- ELE
Maytag LDE9700ACW DRYER- ELE
Maytag LDE9700ADL DRYER- ELE
Maytag LDE9700ADW DRYER- ELE
Maytag LDE9701ACL DRYER- ELE
Maytag LDE9701ACW DRYER- ELE
Maytag LDE9701ADL DRYER- ELE
Maytag LDE9701ADW DRYER- ELE
Maytag LDE9800 DRYER- ELE
Maytag LDE9800ACL DRYER- ELE
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
Maytag LDE9900ADW DRYER- ELE
Maytag LDE9900BCL DRYER- ELE
Maytag LDE9900BCW DRYER- ELE
Maytag LDE9900BDL DRYER- ELE
Maytag LDE9900BDW DRYER- ELE
Maytag LDE9904ACE DRYER- ELE
Maytag LDE9904ACL DRYER- ELE
Maytag LDE9904ACM DRYER- ELE
Maytag LDE9904ADE DRYER- ELE
Admiral LDEA100ACL DRYER- ELE
Admiral LDEA100ACW DRYER- ELE
Admiral LDEA100BCE DRYER- ELE
Admiral LDEA100BCM DRYER- ELE
Admiral LDEA200ACE DRYER- ELE
Admiral LDEA200ACL DRYER- ELE
Admiral LDEA200ACM DRYER- ELE
Admiral LDEA200ACW DRYER- ELE
Admiral LDEA300AGE DRYER- ELE
Admiral LDEA300AGL DRYER- ELE
Admiral LDEA300AGW DRYER- ELE
Admiral LDEA300AKE DRYER- ELE
Admiral LDEA400ACE DRYER- ELE
Admiral LDEA400ACL DRYER- ELE
Admiral LDEA400ACM DRYER- ELE
Admiral LDEA400ACW DRYER- ELE
Admiral LDEA500ACE DRYER- ELE
Admiral LDEA500ACL DRYER- ELE
Admiral LDEA500ACM DRYER- ELE
Admiral LDEA500ACW DRYER- ELE
  #2 (permalink)
Old 03-08-2012, 01:34 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hello.
My strong recommendation is to replace both rollers and also check if the roller shaft is broken or loose.
In regards to your question about dryer running with out one roller the answer is most likely not. I think the roller came off the shaft while you were pulling the drum out.
I also, suggest that you check the idler pulley.
The roller Part number: AP4008534
The shaft Part number: AP4373312
The belt Part number: AP4290988
Here are the breakdown diagram and
Replacement parts for Maytag LDE8704ACM DRYER- ELE | AppliancePartsPros.com
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-08-2012, 01:59 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hello.
I would have thought that too, however before we removed the case and drum we could see the roller on the floor of the dryer through the access panel on the back of the dryer. The shaft and washers were all in tact with the snap ring, so I am not sure that there is anything wrong with the roller. The dryer was apparantly operating this way for some time. Still think we should replace both rollers anyway?
  #4 (permalink)
Old 03-08-2012, 02:26 PM
Expert
Default
There is no miracles. The roller came off the shaft because the opening in the center became much larger then it supposed to be. Yes, I recommend to replace both rollers.
__________________
  #5 (permalink)
Old 03-08-2012, 02:34 PM
Junior Member
Default
I know it sounds wrong but the shaft was still put together inside the roller, along with the washers and snap ring. The roller did not come off of the shaft.
  #6 (permalink)
Old 03-09-2012, 11:24 AM
Expert
Default
Hi.
In this case you should locate the nut laying somewhere at the bottom and if the shaft looks OK reattach it back. See if this will work for you.
__________________
  #7 (permalink)
Old 03-10-2012, 01:39 PM
Junior Member
Default
Just figured out that the entire drum support wheel had worked its way through the metal shroud and enlarged the opening until it completely fell out and onto the floor of the dryer. As I said before, all parts of the wheel were still put together and in tact, including the nut which didn't come off the shaft. Do you think getting a larger washer that will extend over the width of the hole in the metal shroud will work in this situation?
  #8 (permalink)
Old 03-11-2012, 10:24 PM
Expert
Default
Hi.
Before I can answer your question, please make a picture and post it.
__________________
  #9 (permalink)
Old 03-21-2012, 11:25 AM
Junior Member
Default
Hi.
Please respond to this email so I can forward the pics from my phone.
  #10 (permalink)
Old 03-21-2012, 01:17 PM
Expert
Default
Hi.
Here how you can attach the picture.
Click on the "Quick Reply" as you would normally do to create a post. Then click on the "Go advance" right below the reply box. The advanced menue has an "Attachment" button that can be used to attach and post a picture.
Hope this helps.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer repair Vinncent318 Dryer Repair 0 11-08-2011 10:58 AM
maytag dryer repair help levi martinez Dryer Repair 0 07-11-2011 11:54 AM
Please help with Maytag dryer repair... Scoe141 Dryer Repair 0 09-06-2008 02:06 PM
Maytag Dryer Repair emilhogen Dryer Repair 1 07-01-2008 03:08 AM
Dryer Maytag Repair arosamena Dryer Repair 0 01-29-2008 06:00 PM
