My Frigidaire stopped running and now when I try starting it, a buzzing sound comes from the back near the motor elements. Power is fine, door works, drum spins in both directions fine. Do I need to replace the motor, or is there another potential problem, like the thermal limiter (fuse)? Any ideas would be much appreciated!
