| » Frigidaire Code AD |
Quote:
The "AD" in the display would indicate the auto dry cycle has been selected, and the dryer control is trying to determine the needed drying time. "The following will be displayed during an Auto Dry cycle: · The Estimated Drying time for the cycle selected will be displayed for approximately 5 minutes. · The “Ad” is displayed until the Estimated Drying Time for your specific load has been determined. · The cycle status will change from “Auto Dry” to “Cool Down” while the load is being tumbled without heat. · “dn” is displayed when the cycle is done." Without a model number, it's a bit rough to help you out, but If you'r4e selecting the auto dry selection, you need to check and clean the sensor bar in the drum with rubbing alcohol to remove any build up and debris on the sensor bars. If you can get a model number off the serial plate, we can assist you more efficiently and accurately, if this doesn't solve the issue.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Frigidaire Error Code - E47 | Scotts_Spot | Washer Repair | 4 | 01-15-2012 04:41 PM |
| Frigidaire Code 38,37 | addiel | Dishwasher Repair | 0 | 09-20-2011 05:35 AM |
| Frigidaire dishwasher ER code | kshelton | Dishwasher Repair | 1 | 07-17-2009 06:51 AM |
| frigidaire, code, f10 | bvlover2000 | Oven Repair (including Ranges and Cooktops) | 6 | 12-27-2008 12:43 PM |
| f10 code on frigidaire | daisy_delgado89 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2008 02:49 PM |
