johnsil
#1 Posted : Thursday, August 6, 2009 7:55:11 AM(UTC)
johnsil
door switch and thermal fuse are OK. With timer knob in off position timer motor has no power. Turn knob to any position and timer motor has 120V on it. pushing start button does not start dryer. Timer shaft wobbles a little. Before this "no start" ptoblem I had to push the start button a few times to get it to start.
sidfink43
#2 Posted : Saturday, August 8, 2009 1:12:56 PM(UTC)
sidfink43
High John
Unplug the machine and take off the wires from the start switch and tape them together. Then carefully plug in the machine and see if it starts. If it does, try replacing the start switch. If it still does not start the motor is probably going bad. DO NOT EVER OPERATE THIS MACHINE IN THIS MANNER, THIS IS FOR DIAGNOSIS ONLY.
If it will not start, the motor is likely going bad.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
