Discuss
whirlpool gas dryer no heat or only warm
 in
Dryer Repair
question,,my gas dryer doesnt get hot,,,,when cold first load it fires up ,,then after a few cycles i noticed no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool gas dryer no heat or only warm
  #1 (permalink)
Old 03-05-2012, 02:47 PM
Junior Member
mgasv is on a distinguished road
Default whirlpool gas dryer no heat or only warm
Model Number: lgr8648LWO   Brand: Whirlpool   Age: 5 - 10 years
question,,my gas dryer doesnt get hot,,,,when cold first load it fires up ,,then after a few cycles i noticed no flame(gas).. i have checked coils witha meter and get correct reading..(i check them cold after i had removed them from machine... i have seen the fire up cold thur the peak hole in front ...all of the vents are cleaned,,test all fuses in rear witha meter,, i have seen a few time during the drying clcle the flame turn on but never gets the dryer hot...befor i wrote this i checked out thur the peak hole and noticed that it glowed and no gas came,,the glowing cycle turn on then off in a cycle but no flame....so what would be my next step to check out???
Ads By Google
Related Models
Whirlpool LGR8648PG0 29"gas Dryer
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" Gas Dryer
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"gas Dryer
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0
Whirlpool LGR8857EQ1
Whirlpool LGR8857EQ2
Whirlpool LGR8857EQ3
Whirlpool LGR8857EZ0
Whirlpool LGR8857EZ1
Whirlpool LGR8857EZ2
Whirlpool LGR8857EZ3
Whirlpool LGR8858DQ0
Whirlpool LGR8858DQ1
Whirlpool LGR8858DZ0
Whirlpool LGR8858DZ1
Whirlpool LGR8858EQ0
Whirlpool LGR8858EQ1
Whirlpool LGR8858EQ2
Whirlpool LGR8858EQ3
Whirlpool LGR8858EZ0
Whirlpool LGR8858EZ1
Whirlpool LGR8858EZ2
Whirlpool LGR8858EZ3
Amana LGS10AW Washer - Top Loading
Amana LGS19AW Dryer - Gas
Amana LGS33AW Dryer - Gas
Amana LGS34AW Washer - Top Loading
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
Whirlpool LGT7646DQ1
Whirlpool LGT7646DZ0
Whirlpool LGT7646DZ1
Whirlpool LGT7646EQ0
Whirlpool LGT7646EQ1
Whirlpool LGT7646EQ2
Whirlpool LGT7646EQ3
Whirlpool LGT7646EZ0
Whirlpool LGT7646EZ1
Whirlpool LGT7646EZ2
Whirlpool LGT7646EZ3
Whirlpool LGT7848AN0
Whirlpool LGT7848AQ0
Whirlpool LGT7848AQ1
Whirlpool LGT7848AQ2
Whirlpool LGT7848AW0
Whirlpool LGT7848AZ0
Whirlpool LGT7848AZ1
Whirlpool LGT7848AZ2
Whirlpool LGT7848DQ0
Whirlpool LGT7848DQ1
Whirlpool LGT7848DZ0
Whirlpool LGT7848DZ1
Whirlpool LGT8858AN0
Whirlpool LGT8858AN1
Whirlpool LGT8858AN2
Whirlpool LGT8858AQ0
Whirlpool LGT8858AQ1
Whirlpool LGT8858AQ2
Whirlpool LGT8858AW0
Whirlpool LGT8858AW1
Whirlpool LGT8858AW2
Whirlpool LGT8858AZ0
Whirlpool LGT8858AZ1
Whirlpool LGT8858AZ2
Whirlpool LGT8858DQ0
Whirlpool LGT8858DQ1
Whirlpool LGT8858DZ0
Whirlpool LGT8858DZ1
Whirlpool LGV4434AN0
Whirlpool LGV4434AW0
  #2 (permalink)
Old 03-05-2012, 05:01 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hello.
Most likely you have bad control coils. They are relatively easy to replace. The second choice is the safety gas valve assembly - comes with the coils. I would suggest you to start with coils. The unused parts, purchased from us can be returned.
The control coils set Part number: AP3094251
The safety gas valve Part number: AP3081145
Here are the breakdown diagrams and Replacement parts for Whirlpool LGR8648LW0 RESIDENTIAL DRYER | AppliancePartsPros.com
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-06-2012, 05:43 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hello.
tell me why i can have a good coil test with a meter(tested ohms reading on coils)and you think i should replace them....im dont saying you could be wrong just trying to understand how i could get a good reading on each coil and they still could be the reason for replacement
  #4 (permalink)
Old 03-06-2012, 11:23 AM
Expert
Default
Hi.
You need to take reading of the coils right after gas fail to ignite. First check the coil with 2 contacts. When the defective coil gets hot it's ether opens or shorts. On my experience the bad safety valve is very seldom case.
I hope I've answered your question.
Please post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up NVChickey Dryer Repair 1 02-25-2012 11:52 PM
Whirlpool Dryer, getting Heat on NO heat setting. gph1 Dryer Repair 1 09-24-2010 01:09 PM
Dryer will not heat provides air luke warm Janice Dobrinich Dryer Repair 1 02-08-2010 02:18 PM
Whirlpool dryer barely warm, dries too slowly. DoninHouston Dryer Repair 2 02-07-2009 03:32 AM
Whirlpool dryer won't ignite when warm Lou9697 Dryer Repair 2 09-04-2008 08:34 PM
