Discuss
whirlpool dryer no heat
 in
Dryer Repair
My gas dryer runs fine for one load but then in follow up loads gas flame will not ignite. Vent
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer no heat
  #1 (permalink)
Old 03-03-2012, 10:13 AM
Junior Member
McAndrew11 is on a distinguished road
Default whirlpool dryer no heat
Model Number: LGB6400kq1   Brand: Whirlpool   Age: 5 - 10 years
My gas dryer runs fine for one load but then in follow up loads gas flame will not ignite. Vent is all cleaned out. I have replaced coil and thermal fuse. Still not working.
Ads By Google
Related Models
Whirlpool LGB6400KQ1
Whirlpool LGB6400LW0
Whirlpool LGB6400LW1 29"gas Dryer
Admiral LGC1330ADB Surface Unit - Gas
Admiral LGC1330ADC Surface Unit - Gas
Admiral LGC1330ADW Surface Unit - Gas
Amana LGC20AW Dryer - Gas
Whirlpool LGC5000PQ0 29" Gas Dryer
Whirlpool LGC5000PQ1 29" Gas Dryer
Amana LGC50AW Dryer - Gas
Whirlpool LGC6646AN0
Whirlpool LGC6646AN1
Whirlpool LGC6646AN2
Whirlpool LGC6646AQ0
Whirlpool LGC6646AQ1
Whirlpool LGC6646AQ2
Whirlpool LGC6646AW0
Whirlpool LGC6646AW1
Whirlpool LGC6646AW2
Whirlpool LGC6646AZ0
Whirlpool LGC6646AZ1
Whirlpool LGC6646AZ2
Whirlpool LGC6848AN0
Whirlpool LGC6848AN1
Whirlpool LGC6848AN2
Whirlpool LGC6848AN3
Whirlpool LGC6848AQ0
Whirlpool LGC6848AQ1
Whirlpool LGC6848AQ2
Whirlpool LGC6848AQ3
Whirlpool LGC6848AW0
Whirlpool LGC6848AW1
Whirlpool LGC6848AW2
Whirlpool LGC6848AW3
Whirlpool LGC6848AZ0
Whirlpool LGC6848AZ1
Whirlpool LGC6848AZ2
Whirlpool LGC6848AZ3
Whirlpool LGC7646DQ0
Whirlpool LGC7646DQ1
Whirlpool LGC7646DZ0
Whirlpool LGC7646DZ1
Whirlpool LGC7848DQ0
Whirlpool LGC7848DQ1
Whirlpool LGC7848DZ0
Whirlpool LGC7848DZ1
Whirlpool LGC7858AN0
Whirlpool LGC7858AN1
Whirlpool LGC7858AN2
Whirlpool LGC7858AQ0
Whirlpool LGC7858AQ1
Whirlpool LGC7858AQ2
Whirlpool LGC7858AW0
Whirlpool LGC7858AW1
Whirlpool LGC7858AW2
Whirlpool LGC7858AZ0
Whirlpool LGC7858AZ1
Whirlpool LGC7858AZ2
Whirlpool LGC8858DQ0
Whirlpool LGC8858DQ1
Whirlpool LGC8858DZ0
Whirlpool LGC8858DZ1
Whirlpool LGC8858EQ0
Whirlpool LGC8858EQ1
Whirlpool LGC8858EQ2
Whirlpool LGC8858EQ3
Whirlpool LGC8858EZ0
Whirlpool LGC8858EZ1
Whirlpool LGC8858EZ2
Whirlpool LGC8858EZ3
Whirlpool LGC9000PW0 29" Gas Dryer
Whirlpool LGC9000PW1 29" Gas Dryer
Amana LGD20AW Dryer - Gas
Amana LGD251 Dryer - Gas
Amana LGD312 Dryer - Gas
Amana LGD32AW Dryer - Gas
Amana LGD451 Dryer - Gas
Amana LGD512 Dryer - Gas
Amana LGD57AW Dryer - Gas
Amana LGD65AW Dryer - Gas
Amana LGD851 Dryer - Gas
Amana LGD912 Dryer - Gas
Amana LGD951 Washer - Top Loading
Whirlpool LGE9848BQ1
Whirlpool LGE9848BQ2
Whirlpool LGE9848BZ1
Whirlpool LGE9848BZ2
Whirlpool LGL7646EQ0
Whirlpool LGL8858DQ0
Whirlpool LGL8858DZ0
Whirlpool LGL8858EQ0
Whirlpool LGL8858EQ1
Whirlpool LGL8858EQ2
Whirlpool LGL8858EQ3
Amana LGM439L Dryer - Gas
Amana LGM439W Dryer - Gas
Amana LGM449L Dryer - Gas
Amana LGM449W Dryer - Gas
Amana LGM549L Dryer - Gas
Amana LGM549W Dryer - Gas
Amana LGM849W Dryer - Gas
Whirlpool LGN1000HQ0
Whirlpool LGN1000HQ1
Whirlpool LGN1000PQ0 29"gas Dryer
Whirlpool LGN1000PQ1 29"gas Dryer
Whirlpool LGN2000JQ0
Whirlpool LGN2000JQ1
Whirlpool LGN2000JQ2
Whirlpool LGN2000JQ3
Whirlpool LGN2000JT0
Whirlpool LGN2000JT1
Whirlpool LGN2000JT2
Whirlpool LGN2000JT3
  #2 (permalink)
Old 03-03-2012, 10:34 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Did you also clean out around the blower housing?
If so then you may have a week ignitor.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 03-03-2012, 10:40 AM
Junior Member
Default
blower housing appears to be clean. should I replace igniter?
  #4 (permalink)
Old 03-07-2012, 04:48 PM
Junior Member
Default
OK- I have replaced the igniter with same results. It fires up on first load but after that coil lights up but no flame. If I let it cool down for 20 minutes it will fire up again. What do I replace now??!!! FLame sensor?
  #5 (permalink)
Old 03-07-2012, 05:11 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Tell me, please , if the ignitor glows and shots off? If it does then most likely you need to replace the safety gas valve (comes with new set of coils). When replacing it don't forget to turn the gas off.
The safety gas valve Part number: AP3081145
Here is the breakdown diagrams and Replacement parts for Whirlpool LGB6400KQ1 DRYER | AppliancePartsPros.com
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #6 (permalink)
Old 03-28-2012, 06:04 AM
Junior Member
Default
is there a video or directions on how to replace this part?
  #7 (permalink)
Old 03-28-2012, 04:18 PM
Expert
Default
Hi.
To remove the gas valve :
- Turn the gas off.
- disconnect the gas line from the dryer.
- remove the back panel.
- take the bracket off the end gas pipe.
- remove screws holding the burner to the bottom.
- pull out the assembly. Note - be very careful not to brake the ignitor.
- remove two screws holding valve to the bracket.
- install orifice from old valve to the new one if needed.
- reinstall everything .
I hope this will help you.
Thank you. Post the results.
Simon.
__________________
  #8 (permalink)
Old 04-02-2012, 06:06 AM
Junior Member
Default
So I replaced the gas valve. The igniter glows and the flame burns but not for the whole cycle. I am thinking it is the flame sensor- any thoughts??
  #9 (permalink)
Old 04-02-2012, 03:32 PM
Expert
Default
Hi.
The gas flame is not suppose to stay on all the time the dryer is on. It cycles on and off. 2-3 min. on then 1min. off.
Thank you.
Simon.
__________________
  #10 (permalink)
Old 04-02-2012, 04:31 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Thank you.
Simon.
It burns for a part of the cycle then stops. It never reignites leaving a load of laundry still damp.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up NVChickey Dryer Repair 1 02-25-2012 11:52 PM
whirlpool dryer doesn't heat up tjwinters Dryer Repair 2 11-24-2011 03:22 AM
Whirlpool Dryer, getting Heat on NO heat setting. gph1 Dryer Repair 1 09-24-2010 01:09 PM
Whirlpool dryer won't heat Rans Dryer Repair 1 02-12-2010 05:08 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
