Here are your parts, includes a wiring diagram.
Replacement parts for Admiral ADE7000AYW DRYER- ELE | AppliancePartsPros.comFirst thing to check is the power.
The motor etc runs off of 120 volts but the heating coil needs the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If the power is OK unplug the unit and check the heating coil with a meter.
It should be around 10 to 12 ohms.
If OK check the thermostats, they should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
