Discuss
Maytag Electric Dryer Timing Cycle
 in
Dryer Repair
My Maytag dryer has the following problem...it runs fine except for the following abnormality: after I select the dry temperature
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Electric Dryer Timing Cycle
  #1 (permalink)
Old 08-04-2009, 09:36 AM
Junior Member
GlennAbello is on a distinguished road
Default Maytag Electric Dryer Timing Cycle
Model Number: LDE9334ACE   Brand: Maytag   Age: More than 10 years
My Maytag dryer has the following problem...it runs fine except for the following abnormality: after I select the dry temperature setting (regular, delicate, etc.) and the dry cycle (timed dry, automatic, etc.) and press the start button, evrything seems to work fine. The dryer motor turns the tumbling assembly, the heater warms the clothing load, but the cycle selector does NOT count down the time remaining for the machine to work, even though the load may have dried in 30-45 minutes. I think that this may be a faulty timer unit, but I want to verify this before I order this part. Thanks for your kind assistance.
Regards,
Glenn Abello
glennabello@yahoo.com
Ads By Google
Related Models
Maytag LDE9334ACE DRYER- ELE
Maytag LDE9334ACL DRYER- ELE
Maytag LDE9334ACM DRYER- ELE
Maytag LDE9334ADE DRYER- ELE
Maytag LDE9606ACE DRYER- ELE
Maytag LDE9606ACM DRYER- ELE
Maytag LDE9606ADE DRYER- ELE
Maytag LDE9606ADM DRYER- ELE
Maytag LDE9606AEE DRYER- ELE
Maytag LDE9700 DRYER- ELE
Maytag LDE9700ACL DRYER- ELE
Maytag LDE9700ACW DRYER- ELE
Maytag LDE9700ADL DRYER- ELE
Maytag LDE9700ADW DRYER- ELE
Maytag LDE9701ACL DRYER- ELE
Maytag LDE9701ACW DRYER- ELE
Maytag LDE9701ADL DRYER- ELE
Maytag LDE9701ADW DRYER- ELE
Maytag LDE9800 DRYER- ELE
Maytag LDE9800ACL DRYER- ELE
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
Maytag LDE9900ADW DRYER- ELE
Maytag LDE9900BCL DRYER- ELE
Maytag LDE9900BCW DRYER- ELE
Maytag LDE9900BDL DRYER- ELE
Maytag LDE9900BDW DRYER- ELE
Maytag LDE9904ACE DRYER- ELE
Maytag LDE9904ACL DRYER- ELE
Maytag LDE9904ACM DRYER- ELE
Maytag LDE9904ADE DRYER- ELE
Admiral LDEA100ACL DRYER- ELE
Admiral LDEA100ACW DRYER- ELE
Admiral LDEA100BCE DRYER- ELE
Admiral LDEA100BCM DRYER- ELE
Admiral LDEA200ACE DRYER- ELE
Admiral LDEA200ACL DRYER- ELE
Admiral LDEA200ACM DRYER- ELE
Admiral LDEA200ACW DRYER- ELE
Admiral LDEA300AGE DRYER- ELE
Admiral LDEA300AGL DRYER- ELE
Admiral LDEA300AGW DRYER- ELE
Admiral LDEA300AKE DRYER- ELE
Admiral LDEA400ACE DRYER- ELE
Admiral LDEA400ACL DRYER- ELE
Admiral LDEA400ACM DRYER- ELE
Admiral LDEA400ACW DRYER- ELE
Admiral LDEA500ACE DRYER- ELE
Admiral LDEA500ACL DRYER- ELE
Admiral LDEA500ACM DRYER- ELE
Admiral LDEA500ACW DRYER- ELE
Hoover LDEH200ACV DRYER- ELE
Hoover LDEH200AGV DRYER- ELE
Hoover LDEH200AKV DRYER- ELE
 LDF6810BB Dishwasher
 LDF6810ST Dishwasher
 LDF6810WW Dishwasher
 LDF6920BB Dishwasher
 LDF6920ST Dishwasher
 LDF6920WW Dishwasher
 LDF7810BB Dishwasher
 LDF7810ST Dishwasher
 LDF7810WW Dishwasher
 LDF7811BB Dishwasher
 LDF7811ST Dishwasher
 LDF7811WW Dishwasher
 LDF7932ST Dishwasher
 LDF8812ST Dishwasher
 LDF9810ST Dishwasher
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
  #2 (permalink)
Old 08-05-2009, 06:35 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Glen
If the timer is not advancing in any setting, including timed then I think the timer is the problem.
Good luck.
__________________
  #3 (permalink)
Old 08-05-2009, 07:43 AM
Junior Member
Default Maytag Dryer timing Problem
Quote:
Originally Posted by sidfink43 View Post
Hi Glen
Good luck.
Hi, Sid...
Thank you very much for your reply. I thought that this was the problem, but wanted an expert's advice before I bought the part. I appreciate your response.
Glenn
  #4 (permalink)
Old 08-05-2009, 08:13 AM
Senior Expert
APP Volunteer
Default
Ok good
I just took a look at that part, and it is expensive. See if there is a "Speed Queen" generic timer available at less cost, or if just the timer motor that can be replaced at a much lower cost.
Good luck, hope that solves it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer timing issues? Craig603 Washer Repair 1 12-21-2009 07:07 PM
maytag electric dryer mastertone5 Dryer Repair 3 04-21-2009 03:06 PM
Maytag Electric Dryer mjg1969 Dryer Repair 1 02-05-2009 05:01 AM
GE electric dryer only works on delicate cycle for heat keithg Dryer Repair 2 11-09-2008 03:36 PM
maytag Electric dryer gws001 Dryer Repair 17 08-14-2007 05:58 PM
