carlM
#1 Posted : Monday, August 3, 2009 12:34:37 PM(UTC)
carlM
my dryer has stopped heating, there is 3 wires going to the heater coil on top of the baffle heater i see 2 bigger wires connected and 1 skinner wire not the unit has a bolt in the center that secures it to the baffle?
I hope this is enough info. and again thanks
sidfink43
#2 Posted : Wednesday, August 5, 2009 5:32:48 AM(UTC)
sidfink43
Hi Carl
Test the safety thermostat on top of the coil housing for continuity, and using the two wires that connect to the coil, test them for continuity and resistance (12 to 20 ohms).
If they check out take off the front and test the thermostats/fuses on the front of the blower housing
Good luck
