Discuss
washer spin problems
 in
Dryer Repair
my washer is a whirlpool, it does wahing cycle ok but when it comes to the spin most of thie
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » washer spin problems
  #1 (permalink)
Old 01-10-2008, 05:59 PM
mimiki mimiki is offline
Junior Member
mimiki is on a distinguished road
Exclamation washer spin problems
Model Number: lxr7144eq1   Brand: Whirlpool   Age: 5 - 10 years
my washer is a whirlpool, it does wahing cycle ok but when it comes to the spin most of thie times it just drain the water ,i have to either move the timer again to the spin cycle or open and close tehe lid in order to get it spin, timer and lid switch been replaced but still same problem ,please help me
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 08:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does it spin without any load?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-12-2008, 10:22 AM
Junior Member
Default washer spin problems
no idoes same thing with or without any load
  #4 (permalink)
Old 01-15-2008, 01:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Possible a transmission going bad.
Remove the cabinet and the pump. Turn the motor shaft clockwise - the clutch disk should turn and release the break. Then turn the motor shaft counterclockwise - the agitator should move.
Post your findings.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer problems sedelen@windstream.net Washer Repair 2 06-10-2008 03:47 AM
washer problems grant Washer Repair 2 11-27-2007 06:49 PM
Washer will not spin Jammin' Jo Washer Repair 0 11-25-2007 08:23 AM
washer won't spin gm589 Washer Repair 6 11-11-2007 02:42 PM
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 09:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
