thabersaat
#1 Posted : Monday, February 27, 2012 11:10:06 AM(UTC)
thabersaat
So my dryer will run for about 15 minutes without the heat kicking in, not sure why, before it gets a error and all the right side panel lights blink and it stops. I have taken my meter to it (my first time using one, hopefully correctly) to check for continuity. Seems the thermostat and limiter both get a reading of 1, the heating element a reading of 12 and originally the thermistor a reading of zero. Just replaced the thermistor, which had a chip out of it and seemed to have exposed element, with a new one and it still does not work. Where do I go from here?
Thanks in advance
T
#2 Posted : Monday, February 27, 2012 2:32:12 PM(UTC)
Make sure there is 240 VAC at the dryer wall outlet.
Did it show any error codes?
Perform the self test as described in the Tech sheet and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire GLEQ2152ES0 Frigidaire/dryer | AppliancePartsPros.com
thabersaat
#3 Posted : Monday, February 27, 2012 5:11:37 PM(UTC)
thabersaat
Okay the dryer outlet is reading 240 as well as the plug terminals at the dryer itself. I also threw my breaker ahead of time and still no heat. The error code that comes up is E5.
I see the solution part of the tech sheet, but am unsure of where the heater relay is located to test.
Thanks for the help Gene.
T-
#4 Posted : Monday, February 27, 2012 7:37:52 PM(UTC)
Check the high limit thermostat (#33 on the diagram) for continuity.
If the high limit thermostat is open, replace it.
If it's good, replace the control board.
- The high limit thermostat Part number: AP2131477
- The control board Part number: AP3851146
thabersaat
#5 Posted : Monday, February 27, 2012 8:01:10 PM(UTC)
thabersaat
I get a continuity reading of 001. So I guess its the control board, figures that it has to be the expensive part. Thanks for your help though!
thabersaat
#6 Posted : Thursday, March 1, 2012 8:32:05 PM(UTC)
thabersaat
Hey Gene,
Just wanted to say thank you again. It was the control board as it turned out that the plastic around the red and black wire connections were burned and melted. I put a new control board in and the dryer runs great.
Thanks!
Travis
#7 Posted : Friday, March 2, 2012 1:57:34 PM(UTC)
You are welcome Travis. I'm glad it's up and running.
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 8/30/2015 2:22:05 PM(UTC)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Dryer does not heat anymore (Dryer Repair)
by yellowsir 2/28/2014 8:09:39 AM(UTC)
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 2/2/2013 7:47:15 AM(UTC)
Dryer does not heat, but runs, all parts seem to be good (Dryer Repair)
by discgolfdoug 10/14/2012 8:01:10 PM(UTC)
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 9/28/2012 6:21:38 AM(UTC)
Kenmore H3 Dryer does not heat (Dryer Repair)
by tim75 8/7/2012 10:12:46 AM(UTC)
by tomromeyn7 6/3/2012 2:57:52 PM(UTC)
Electric dryer does not heat. (Dryer Repair)
by Wtucker 4/19/2012 11:10:26 AM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by lingo622 9/22/2011 12:03:52 PM(UTC)
Whirlpool dryer does not heat on medium setting (Dryer Repair)
by redcagle 7/28/2011 10:55:43 AM(UTC)
by nwiccauto 6/16/2011 10:02:50 AM(UTC)
Whirlpool dryer does not heat (Dryer Repair)
by jkaffel 5/19/2011 2:34:34 PM(UTC)
by David schuler 4/26/2011 12:29:11 PM(UTC)
