Discuss
whirlpool clean touch dryer
 in
Dryer Repair
after reading a post i manually rotated the drum while pushing the start button.....ran for 13 minutes .....twice....once each day.....after
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool clean touch dryer
  #1 (permalink)
Old 08-01-2009, 11:52 AM
Junior Member
davidg.46 is on a distinguished road
Default whirlpool clean touch dryer
Model Number: lgc6646aq0   Brand: Whirlpool   Age: 1 - 5 years
after reading a post i manually rotated the drum while pushing the start button.....ran for 13 minutes .....twice....once each day.....after that when u push the button and it just buzzes........heats well and timer runs
Related Models
Whirlpool LGC6646AQ0 Residential Dryer
Whirlpool LGC6646AQ1 GAS DRYER
Whirlpool LGC6646AQ2 GAS DRYER
Whirlpool LGC6646AW0 Residential Dryer
Whirlpool LGC6646AW1 GAS DRYER
Whirlpool LGC6646AW2 GAS DRYER
Whirlpool LGC6646AZ0 Dryer
Whirlpool LGC6646AZ1 GAS DRYER
Whirlpool LGC6646AZ2 GAS DRYER
Whirlpool LGC6848AN0 GAS DRYER
Whirlpool LGC6848AN1 GAS DRYER
Whirlpool LGC6848AN2 GAS DRYER
Whirlpool LGC6848AN3 GAS DRYER
Whirlpool LGC6848AQ0 Residential Dryer
Whirlpool LGC6848AQ1 GAS DRYER
Whirlpool LGC6848AQ2 GAS DRYER
Whirlpool LGC6848AQ3 GAS DRYER
Whirlpool LGC6848AW0 GAS DRYER
Whirlpool LGC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LGC6848AW2 GAS DRYER
Whirlpool LGC6848AW3 GAS DRYER
Whirlpool LGC6848AZ1 GAS DRYER
Whirlpool LGC6848AZ2 GAS DRYER
Whirlpool LGC6848AZ3 GAS DRYER
Whirlpool LGC7646DQ0 GAS DRYER
Whirlpool LGC7646DQ1 GAS DRYER
Whirlpool LGC7646DZ0 GAS DRYER
Whirlpool LGC7646DZ1 GAS DRYER
Whirlpool LGC7848DQ0 GAS DRYER
Whirlpool LGC7848DQ1 GAS DRYER
Whirlpool LGC7848DZ0 GAS DRYER
Whirlpool LGC7848DZ1 GAS DRYER
Whirlpool LGC7858AN0 GAS DRYER
Whirlpool LGC7858AN1 GAS DRYER
Whirlpool LGC7858AN2 GAS DRYER
Whirlpool LGC7858AQ0 GAS DRYER
Whirlpool LGC7858AQ1 GAS DRYER
Whirlpool LGC7858AQ2 GAS DRYER
Whirlpool LGC7858AW0 Residential Dryer
Whirlpool LGC7858AW1 GAS DRYER
Whirlpool LGC7858AW2 GAS DRYER
Whirlpool LGC7858AZ0 GAS DRYER
Whirlpool LGC7858AZ1 GAS DRYER
Whirlpool LGC7858AZ2 GAS DRYER
Whirlpool LGC8858DQ0 GAS DRYER
Whirlpool LGC8858DQ1 GAS DRYER
Whirlpool LGC8858DZ0 GAS DRYER
Whirlpool LGC8858DZ1 GAS DRYER
Whirlpool LGC8858EQ0 GAS DRYER
Whirlpool LGC8858EQ1 DRYERS
Whirlpool LGC8858EQ2 GAS DRYER
Whirlpool LGC8858EQ3 GAS DRYER
Whirlpool LGC8858EZ0 GAS DRYER
Whirlpool LGC8858EZ1 DRYERS
Whirlpool LGC8858EZ2 GAS DRYER
Whirlpool LGC8858EZ3 GAS DRYER
Whirlpool LGC9000PW0 29" GAS DRYER
Whirlpool LGC9000PW1 29" GAS DRYER
Amana LGD20AW DRYER- GAS
Amana LGD251 WASHER-TOP LOADING
Amana LGD251 DRYER- GAS
Amana LGD312 DRYER- GAS
Amana LGD32AW DRYER- GAS
Amana LGD451 WASHER-TOP LOADING
Amana LGD451 DRYER- GAS
Amana LGD512 DRYER- GAS
Amana LGD57AW DRYER- GAS
Amana LGD65AW DRYER- GAS
Amana LGD851 WASHER-TOP LOADING
Amana LGD851 DRYER- GAS
Amana LGD912 DRYER- GAS
Amana LGD951 WASHER-TOP LOADING
Amana LGD951 DRYER- GAS
Whirlpool LGE9848BQ1 GAS DRYER
Whirlpool LGE9848BQ2 GAS DRYER
Whirlpool LGE9848BZ1 GAS DRYER
Whirlpool LGE9848BZ2 GAS DRYER
Frigidaire LGEF3031KBA ELECTRIC RANGE
Frigidaire LGEF3031KBB ELECTRIC RANGE
Frigidaire LGEF3031KBC ELECTRIC RANGE
Frigidaire LGEF3031KMA ELECTRIC RANGE
Frigidaire LGEF3031KMB ELECTRIC RANGE
Frigidaire LGEF3031KWA ELECTRIC RANGE
Frigidaire LGEF3031KWB ELECTRIC RANGE
Frigidaire LGEF3031KWC ELECTRIC RANGE
Frigidaire LGEF3033KBA ELECTRIC RANGE
Frigidaire LGEF3033KBB ELECTRIC RANGE
Frigidaire LGEF3033KBC ELECTRIC RANGE
Frigidaire LGEF3033KBD ELECTRIC RANGE
Frigidaire LGEF3033KBE ELECTRIC RANGE
Frigidaire LGEF3033KQA ELECTRIC RANGE
Frigidaire LGEF3033KQB ELECTRIC RANGE
Frigidaire LGEF3033KQC ELECTRIC RANGE
Frigidaire LGEF3033KQD ELECTRIC RANGE
Frigidaire LGEF3033KQE ELECTRIC RANGE
Frigidaire LGEF3033KWA ELECTRIC RANGE
Frigidaire LGEF3033KWB ELECTRIC RANGE
Frigidaire LGEF3033KWC ELECTRIC RANGE
Frigidaire LGEF3033KWD ELECTRIC RANGE
Frigidaire LGEF3033KWE ELECTRIC RANGE
Frigidaire LGEF3041KFA ELECTRIC RANGE
Frigidaire LGEF3041KFC ELECTRIC RANGE
Frigidaire LGEF3041KFD ELECTRIC RANGE
Frigidaire LGEF3043KFA ELECTRIC RANGE
Frigidaire LGEF3043KFB ELECTRIC RANGE
Frigidaire LGEF3043KFC ELECTRIC RANGE
Frigidaire LGEF3043KFD ELECTRIC RANGE
Frigidaire LGEF3043KFE ELECTRIC RANGE
Frigidaire LGEF3043KFF ELECTRIC RANGE
Frigidaire LGEF3043KFG ELECTRIC RANGE
Frigidaire LGEF3045KFA ELECTRIC RANGE
Frigidaire LGEF3045KFB ELECTRIC RANGE
Frigidaire LGEF3045KFC ELECTRIC RANGE
Frigidaire LGEF3045KFD ELECTRIC RANGE
Frigidaire LGEF3045KFE ELECTRIC RANGE
Frigidaire LGEF3045KFF ELECTRIC RANGE
Frigidaire LGEF304DKFA ELECTRIC RANGE
  #2 (permalink)
Old 08-02-2009, 12:12 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Sounds very much like a new motor will fix your problems.
If you try it let us know what happens.
Good luck!
__________________
  #3 (permalink)
Old 08-02-2009, 01:48 PM
Junior Member
Default
i will thank u .......part number by chance just to confirm what i have.
Good luck!
  #4 (permalink)
Old 08-02-2009, 01:54 PM
Senior Expert
APP Volunteer
Default
Here's what comes up on this site.
Part number: AP3094245
Note that this is an APP number. They generally have the lowest prices (and no we do not work for them)
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool touch pad control partsman1 Oven Repair (including Ranges and Cooktops) 3 01-10-2010 02:18 AM
whirlpool clean touch heather16173 Washer Repair 0 12-26-2009 03:59 PM
Whirlpool touch pad greaper Dishwasher Repair 1 06-03-2009 04:05 AM
whirlpool-sealing divider hot to the touch knalang04 General Talk 1 12-26-2008 12:17 PM
How to install Touch pad WhirlPool Oven EricT Oven Repair (including Ranges and Cooktops) 3 12-14-2007 03:59 PM
