Discuss
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up
 in
Dryer Repair
I have a Whirlpool Thin Twin Washer Dryer combo, Model # LTE5243DQ2, that the dryer will not heat up. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up
  #1 (permalink)
Old 02-25-2012, 11:50 PM
Junior Member
NVChickey is on a distinguished road
Question Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up
Model Number: LTE5243DQ2   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool Thin Twin Washer Dryer combo, Model # LTE5243DQ2, that the dryer will not heat up. I had this unit in my RV and it worked just fine. Then I sold the RV and moved the unit to my home, but along the way (trying to get it out of the RV) it got dropped. I have checked the Internal Bias Thermostat, the Thermal Fuse, the Heater Box Thermostat and the Heater Element for continuity and found them all to have continuity. I know nothing about appliances - but have been trying to do an exhaustive search of the internet for help on this matter. The drum turns just fine. There is no lint in the dryer at all - it has been taken totally apart trying to figure this out. I've checked the 220 wall plug to make sure it is wired correctly. I've gotten all the schematics and part numbers for the washer and dryer and tried to go though them to figure out what it may be. I am retired, on a limited income, and cannot contact a service person. I've been living without the dryer for the past three years - but would really like to get it working. The washer works just fine. Really like this unit. It fits in my home just perfectly. I bought a digital multimeter today and think I have it figured out. I've tried to test wires, the thermostats and the heating element with it - not absolutely positive I'm doing it right. So, any ideas as to where I can look now?
Ads By Google
Related Models
Whirlpool LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ3 LAUNDRY CENTER
Whirlpool LTE5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT2 LAUNDRY SYSTEM
Whirlpool LTE5243DT3 LAUNDRY CENTER
Whirlpool LTE5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5500W1 ELECTRIC DRYER
Whirlpool LTE6234AN0 WASHER/DRYER
Whirlpool LTE6234AN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN3 COMBINATION UNITS
Whirlpool LTE6234AW0 WASHER/DRYER
Whirlpool LTE6234AW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW3 COMBINATION UNITS
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6243AN2 LAUNDRY CENTER
Whirlpool LTE6243AW2 LAUNDRY CENTER
Whirlpool LTE7245AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE7245AW0 WASHER/DRYER LAUNDRY SYSTEM
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB REF - TOP MOUNT
Admiral LTF1812ARW REF - TOP MOUNT
Admiral LTF1812ARZ REF - TOP MOUNT
Admiral LTF2112ARB REF - TOP MOUNT
Admiral LTF2112ARW REF - TOP MOUNT
Admiral LTF2112ARZ REF - TOP MOUNT
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2140FS1 WASHER
Frigidaire LTF2140FS2 WASHER
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF2940FE1 WASHER
Frigidaire LTF2940FS1 WASHER
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF530FS1 WASHER
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF6700FS0 WASHER
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Frigidaire LTF8000FE0 WASHER
Whirlpool LTG5243BN0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN1 COMBINATION UNITS
Whirlpool LTG6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN3 COMBINATION UNITS
Whirlpool LTG6234AW0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW1 COMBINATION UNITS
Whirlpool LTG6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW3 COMBINATION UNITS
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
  #2 (permalink)
Old 02-25-2012, 11:52 PM
Junior Member
Exclamation Whirlpool Thin Twin Dryer no heating up
Almost forgot - the dryer is an electric model. Thanks in advance for any help you can give!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool thin twin dryer doesn't always start nzdw22 Dryer Repair 1 06-28-2011 04:27 AM
Whirlpool heavy duty thin twin dryer-runs but no heat johnb714 Dryer Repair 5 02-17-2011 08:34 AM
Whirlpool thin twin stackable washer and dryer numisman1@yahoo.com Dryer Repair 2 12-14-2009 08:21 PM
Whirlpool Thin Twin dryer will not heat bolingmike Dryer Repair 0 07-29-2008 01:42 PM
Thin Twin Washer Dryer Theadore General Talk 1 08-30-2007 01:28 PM
