Discuss
Maytag Gas Dryer Lights on, Doesn't start
 in
Dryer Repair
My Maytag Neptune Gas Dryer has a continuous display on the control panel showing sensor dry and 63 minutes remaining.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Gas Dryer Lights on, Doesn't start
  #1 (permalink)
Old 07-31-2009, 10:35 AM
Junior Member
volantem is on a distinguished road
Smile Maytag Gas Dryer Lights on, Doesn't start
Model Number: MDG6800AWW   Brand: Maytag   Age: 1 - 5 years
My Maytag Neptune Gas Dryer has a continuous display on the control panel showing sensor dry and 63 minutes remaining. I can't turn it off or use any of the control pad keys. I've unplugged it and when I plug it back in, the display remains the same.
Finally, I broke down and bought a new control board from Appliance Pros, since that seemed to often be the problem. When I put the new control board the same thing happened, but with 50 minutes remaining instead. I checked the door switch and it seems to be functioning properly.
Thanks, Mike.
Related Models
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
Maytag MDG9606BWQ DRYER- GAS
Maytag MDG9606BWW DRYER- GAS
Maytag MDG9700AWM DRYER- GAS
Maytag MDG9700AWW DRYER- GAS
Maytag MDG9706AWA DRYER- GAS
Maytag MDG9706AWW DRYER- GAS
Maytag MDG9766AWW DRYER- GAS
Maytag MDG9766AXW DRYER- GAS
Maytag MDG9800AWQ DRYER- GAS
Maytag MDG9800AWW DRYER- GAS
Maytag MDG9806AWA DRYER- GAS
Maytag MDG9806AWW DRYER- GAS
Maytag MDG9876AWW DRYER- GAS
Maytag MDGT236AWW DRYER- GAS
Maytag MDGT336AWW DRYER- GAS
Maytag MDGT446AWW DRYER- GAS
Frigidaire MDH13TN2
Frigidaire MDH13TN3
Frigidaire MDH15FN1
  #2 (permalink)
Old 08-01-2009, 07:33 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Well, I am sorry that rather expensive part did not fix it. If it is any consolation I am fairly sure that most of us would have recommended you change out the control board, so what you did was the right thing even if the result was not good.
I have not worked on the electronic version of this dryer (just worked on a mechanical one today) but looking at the wiring diagram the two things that it shows interfacing with the board are a thermistor and of course the membrane switches. I think they are your next suspects.
Here is the service manual for your dryer, but I cannot say its trouble shooting guide is any help, buyt maybe the wiring diagram will help.
http://www.servicematters.com/maytag...s/16023110.pdf
Good luck, let us know if you find the problem.
__________________
  #3 (permalink)
Old 08-03-2009, 07:15 AM
Junior Member
Default
Thanks for the help, but after using a multi-tester to check the door switch, thermistor and thermal fuse, which all tested out O.K., I decided to buy a new machine. I bought an Admiral (without the electronic bells and whistles) from Home Depot for $400 delivered. The thing that bothered me the most is that the Maytag is going to end up in a landfill somewhere, and it's just over 3 years old. Thanks again for your help.
-mv
  #4 (permalink)
Old 08-03-2009, 08:16 AM
Senior Expert
APP Volunteer
Default
Well, I am sorry that did not work out. You have experienced first hand what those of us who work on these things have experienced daily, that the microprocesser CPU's in these machines are a disaster.
Your new machine will clean your clothes just as well as a fancy front loader, and be much less likely to need repair.
I know what you mean about going into the landfill. I volunteer and fix appliances for a non-profit home store. Appliances are donated, and we test and repair as needed, and re-sell to raise money for the cause. On an annual basis we keep about 2,000+ washers, dryers, dishwashers, ranges, refrigeratorfs etc from the landfill. What we cannot fix we part out. All in all, pretty satisfying work (except for the no-pay)
Good luck with your new machine.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer will not start Jay Wiggins Dryer Repair 4 05-15-2010 04:06 PM
Maytag Dryer won't start ssp123 Dryer Repair 2 02-16-2010 08:06 PM
Maytag gas dryer lights but shuts off donschaller Dryer Repair 0 01-07-2010 07:26 PM
Maytag dishwasher, no lights on, won't start surplus Dishwasher Repair 3 10-21-2009 10:45 AM
Maytag dryer WON'T START ! souptafied Dryer Repair 1 05-24-2009 06:30 PM
