| » Admiral Dryer won't heat up! |
Model Number: LNC8745A71 Brand: Admiral Age: 5 - 10 years
Need technical help please:
My dryer operates (i.e., spins clothes) but will not heat up clothes without running through the "timed cycle" of 130 minutes at least 4 times! Obviously, this is a huge waste of time and energy! The filter and tube are clear. I was told it might be an "igniter"? Can someone please assist me with this problem and what other item or items might be causing this? Thank you |
Is it warm or cold inside the dryer at the end of the cycle?
__________________
Professional appliance repair in Los Angeles, California. |
It is a very low warmth at the end of the cycle. It's almost as if it drying on an extremely light heat. It takes about 4 full 105 minute cycles to get light clothes dry. This has never happened before.
The first thing I would check is the vent hose, venting inside walls, the blower wheel and the air ducts inside the dryer.
__________________
Quote:
ldo29944,
What is the complete model number of the dryer? Is the problem with your dryer is exactly the same as the problem mentioned by mr1m54u or there is something different? Did you check the exhaust line? Gene.
__________________
| Display Modes | |
| admiral washer | margsain | Washer Repair | 3 | 09-05-2008 01:35 PM |
| Dead Admiral Dryer | jwboone1981 | Dryer Repair | 1 | 01-01-2008 02:59 AM |
| admiral washer | bamadadof2 | Washer Repair | 3 | 12-31-2007 12:11 PM |
| capacity plus admiral dryer | broken_dryer_forthuachuca | Dryer Repair | 0 | 11-19-2007 06:43 PM |
| how do i replace a belt on an Admiral Dryer | pookie | Dryer Repair | 3 | 10-11-2007 05:07 AM |
