Discuss
coin op dryer timer starts but dryer doesn't turn on
 in
Dryer Repair
Hi, Looking for suggestions. I have a coin slide operated dryer. I insert money and it turns on the timer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » coin op dryer timer starts but dryer doesn't turn on
  #1 (permalink)
Old 01-09-2008, 05:05 PM
Mike Craw Mike Craw is offline
Junior Member
Mike Craw is on a distinguished road
Default coin op dryer timer starts but dryer doesn't turn on
Brand: -other-   Age: 1 - 5 years
Hi, Looking for suggestions. I have a coin slide operated dryer. I insert money and it turns on the timer but when you press the start button the dryer doesn't start. It had been run by a tennant non-stop for hours. Is there a cool down period? I unplugged it so the timer stopped and would cool down. Or could it be a thermostat or something else?
All comments appreciated!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 12:21 PM
bentwrench1999 bentwrench1999 is offline
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Exclamation coin op dryer timer starts but dryer doesn't turn
We need more info. Model # ?? Gas or Electric? I's probably as simple as a thermal fuse or door switch. Please post all the info you have.. wrench
__________________
  #3 (permalink)
Old 01-10-2008, 12:45 PM
Junior Member
Default
It's an Inglis Commercial Dryer. All the stickers have fallen off it, not sure of the model. It is electric. I was thinking most likely the thermal fuse being if ran non-stop for hours and I tried to use it right after and it wouldn't start. It has been off for 24 hours and the same thing is still happening.
  #4 (permalink)
Old 01-10-2008, 01:52 PM
Senior Expert
APP Volunteer
Thumbs up coin op dryer timer starts but dryer doesn't turn on
Remove the back panel and look for a thermal fuse. Usually a ceramic-housed type. It could be round (about 2" long) or thin about(about 1/2" wide and 2" long. May have one of these numbers on them. 3390719 or 3392519. Let me know what you find.. wrench
__________________
  #5 (permalink)
Old 01-10-2008, 08:26 PM
Junior Member
Default
Thanks, I just went with it being the Thermal fuse and replace it and all is good.
Handy little forum here.
Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Coin-op Dryer will not start robbieandshaka Dryer Repair 1 12-20-2007 10:16 AM
Gas dryer starts fine gas flame runs 10-15 min and then quits Krsolo Dryer Repair 3 10-23-2007 09:44 AM
Maytag Dryer timer won't turn off dugclark Dryer Repair 3 10-22-2007 03:15 AM
Dryer starts then stops Redwings19 Dryer Repair 0 09-20-2007 10:09 AM
Dryer makes rumbling sound when starts Scottnvegas Dryer Repair 3 08-12-2007 09:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
