Discuss
dryer won't turn on only hums and shuts off
 in
Dryer Repair
Dryer stopped working and put in aThermal Fuse. Worked for awhile now it just hums when turned on and then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer won't turn on only hums and shuts off
  #1 (permalink)
Old 07-30-2009, 10:45 AM
Junior Member
karen klomsten is on a distinguished road
Default dryer won't turn on only hums and shuts off
Model Number: lgr5644aw1   Brand: Whirlpool   Age: More than 10 years
Dryer stopped working and put in aThermal Fuse. Worked for awhile now it just hums when turned on and then will shut off. Also vacumned out all the lint from below. Is it worth fixing. Thanks for your help. Karen
Ads By Google
Related Models
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2 GAS DRYER
Whirlpool LGR5644EQ0 GAS DRYER
Whirlpool LGR5644EQ1 DRYERS
Whirlpool LGR5644EQ2 GAS DRYER
Whirlpool LGR5644EQ3 GAS DRYER
Whirlpool LGR5644EZ0 GAS DRYER
Whirlpool LGR5644EZ1 DRYERS
Whirlpool LGR5644EZ2 GAS DRYER
Whirlpool LGR5644EZ3 GAS DRYER
Whirlpool LGR5644JQ0 GAS DRYER
Whirlpool LGR5644JQ1 RESIDENTIAL DRYER
Whirlpool LGR5644JQ2 GAS DRYER
Whirlpool LGR5644JQ3 29" GAS DRYER
Whirlpool LGR5644JT0 GAS DRYER
Whirlpool LGR5644JT1 RESIDENTIAL DRYER
Whirlpool LGR5644JT2 GAS DRYER
Whirlpool LGR5644JT3 29" GAS DRYER
Whirlpool LGR5644PQ0 29" GAS DRYER
Whirlpool LGR5644PQ1 29" GAS DRYER
Whirlpool LGR5700KQ0 DRYER
Whirlpool LGR5700KQ1 DRYER
Whirlpool LGR5700KT0 DRYER
Whirlpool LGR5700KT1 DRYER
Whirlpool LGR5848EQ0 GAS DRYER
Whirlpool LGR5848EQ1 GAS DRYER
Whirlpool LGR5848EQ2 GAS DRYER
Whirlpool LGR5848EQ3 DRYERS
Whirlpool LGR5848EQ4 DRYERS
Whirlpool LGR5848EQ5 GAS DRYER
Whirlpool LGR5848EQ6 GAS DRYER
Whirlpool LGR6611LQ0 RESIDENTIAL DRYER
Whirlpool LGR6611LQ1 29"GAS DRYER
Whirlpool LGR6611PQ0 29" GAS DRYER
Whirlpool LGR6620PQ0 29"GAS DRYER
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Whirlpool LGR6621PQ0 29" GAS DRYER
Whirlpool LGR6634BN0 GAS DRYER
Whirlpool LGR6634BN1 GAS DRYER
Whirlpool LGR6634BN2 GAS DRYER
Whirlpool LGR6634BQ0 GAS DRYER
Whirlpool LGR6634BQ1 GAS DRYER
Whirlpool LGR6634BQ2 GAS DRYER
Whirlpool LGR6634BW0 GAS DRYER
Whirlpool LGR6634BW1 GAS DRYER
Whirlpool LGR6634BW2 GAS DRYER
Whirlpool LGR6634DQ0 GAS DRYER
Whirlpool LGR6634DQ1 GAS DRYER
Whirlpool LGR6634DW0 GAS DRYER
Whirlpool LGR6634DW1 GAS DRYER
Whirlpool LGR6634DZ0 GAS DRYER
Whirlpool LGR6634DZ1 GAS DRYER
Whirlpool LGR6636PW0 29" GAS DRYER
Whirlpool LGR6636PW1 29" GAS DRYER
Whirlpool LGR6638DQ0 GAS DRYER
Whirlpool LGR6638DQ1 GAS DRYER
Whirlpool LGR6638DW0 GAS DRYER
Whirlpool LGR6638DW1 GAS DRYER
Whirlpool LGR6638DZ0 GAS DRYER
Whirlpool LGR6638DZ1 GAS DRYER
Whirlpool LGR6644DQ0 GAS DRYER
Whirlpool LGR6644DQ1 GAS DRYER
Whirlpool LGR6644DZ0 GAS DRYER
Whirlpool LGR6644DZ1 GAS DRYER
Whirlpool LGR6646BN0 GAS DRYER
Whirlpool LGR6646BN1 GAS DRYER
Whirlpool LGR6646BN2 GAS DRYER
Whirlpool LGR6646BW0 GAS DRYER
Whirlpool LGR6646BW1 GAS DRYER
Whirlpool LGR6646BW2 GAS DRYER
Whirlpool LGR6646DN1 GAS DRYER
Whirlpool LGR6646DW1 GAS DRYER
Whirlpool LGR6646PW0 29" GAS DRYER
Whirlpool LGR6646PW1 29" GAS DRYER
Whirlpool LGR6848AN1 GAS DRYER
Whirlpool LGR6848AN2 GAS DRYER
Whirlpool LGR6848AQ2 GAS DRYER
Whirlpool LGR6848AW0 Residential Dryer
Whirlpool LGR6848AW1 GAS DRYER
Whirlpool LGR6848AW2 GAS DRYER
Whirlpool LGR6848AZ2 GAS DRYER
Whirlpool LGR7620KQ0 RESIDENTIAL DRYER
Whirlpool LGR7620KQ1 RESIDENTIAL DRYER
Whirlpool LGR7620KT0 RESIDENTIAL DRYER
Whirlpool LGR7620KT1 RESIDENTIAL DRYER
Whirlpool LGR7620LG0 RESIDENTIAL DRYER
Whirlpool LGR7620LG1 29"GAS DRYER
Whirlpool LGR7620LQ0 RESIDENTIAL DRYER
Whirlpool LGR7620LW0 RESIDENTIAL DRYER
Whirlpool LGR7620LW1 29"GAS DRYER
Whirlpool LGR7645JQ0 GAS DRYER
Whirlpool LGR7645JQ1 GAS DRYER
Whirlpool LGR7645JQ2 DRYER
Whirlpool LGR7646AN0 GAS DRYER
Whirlpool LGR7646AN1 GAS DRYER
Whirlpool LGR7646AN2 GAS DRYER
Whirlpool LGR7646AQ0 GAS DRYER
Whirlpool LGR7646AQ1 GAS DRYER
Whirlpool LGR7646AQ2 GAS DRYER
Whirlpool LGR7646AW0 Residential Dryer
Whirlpool LGR7646AW1 GAS DRYER
Whirlpool LGR7646AW2 GAS DRYER
Whirlpool LGR7646AZ0 GAS DRYER
Whirlpool LGR7646AZ1 GAS DRYER
Whirlpool LGR7646AZ2 GAS DRYER
Whirlpool LGR7646DQ0 GAS DRYER
Whirlpool LGR7646DQ1 GAS DRYER
Whirlpool LGR7646DW0 GAS DRYER
Whirlpool LGR7646DW1 GAS DRYER
Whirlpool LGR7646DZ0 GAS DRYER
Whirlpool LGR7646DZ1 GAS DRYER
Whirlpool LGR7646EQ0 DRYER
Whirlpool LGR7646EQ1 DRYERS
Whirlpool LGR7646EQ2 GAS DRYER
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
  #2 (permalink)
Old 07-30-2009, 02:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You probably need someone to help you with this simple test. Open the door. Push and hold the door switch. Push the start button and manually turn the drum. If it would start then the motor is the culprit.
- The motor Part number: AP3094245
You decision to fix it or not should be based on the dryer condition.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR5644AW1 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-01-2009, 04:27 AM
Junior Member
Default dryer won't run
Thanks Gene for your help. I ordered the new motor plus other parts you suggested. Finally got it all put together and it's running like a new dryer.Your help was greatly appreciated. Great web site. Thanks Karen
  #4 (permalink)
Old 10-01-2009, 05:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Karen. Great job! Thank you for the feedback and good luck with your dryer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer motor hums & will not turn mmaynard Dryer Repair 3 10-06-2012 01:11 AM
Dryer Turns On, Hums Then Shuts Off PISTONGRIPPIN Dryer Repair 0 10-22-2009 09:13 AM
InSink Erator Hums, Blades Turn, Doesn't Work chinahorse Garbage Disposer Repair 0 03-03-2009 05:11 PM
motor hums but drum will not turn judy71635@alltel.net Dryer Repair 1 07-30-2008 08:28 PM
My Mircowave HUMS when I turn in on. CAR417 Microwave Repair 2 05-06-2008 09:51 PM
