Discuss
No heat!
 in
Dryer Repair
I've lost the heat on my gas dryer. It will tumble, just no heat. Think it's maybe the ignitor?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat!
  #1 (permalink)
Old 07-30-2009, 09:19 AM
Junior Member
rookie45 is on a distinguished road
Default No heat!
Brand: GE   Age: 5 - 10 years
  #2 (permalink)
Old 07-30-2009, 11:58 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to provide most accurate advice we need the complete model number of the dryer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-30-2009, 12:19 PM
Junior Member
Default
It's a GE Profile Dryer.
Model#DPSR475GW0WW
  #4 (permalink)
Old 07-30-2009, 05:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are a few parts in the heating circuit which you have to check for continuity. They are: igniter (#717 on the diagram), high limit thermostat (#505 on the diagram), thermostat (#530 on the diagram), heat detector (#552 on the diagram) and gas valve coils (#729 & #731 on the diagram).
Here are the breakdown diagrams and Replacement parts for GE DPSR475GW0WW | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Normal Heat Empty, Heat Shuts Off Full BigDaddyG Dryer Repair 4 08-06-2009 03:17 PM
No Heat While Turning, Heat When Stopped thou msg2008 Dryer Repair 1 08-07-2008 05:08 AM
