Discuss
Whirpool dryer heating problem
 in
Dryer Repair
Dryer will not heat on lower heat cycles. It will heat on higher heat cycles. Could it be the cycling
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirpool dryer heating problem
  #1 (permalink)
Old 07-30-2009, 08:25 AM
Junior Member
windsordan is on a distinguished road
Default Whirpool dryer heating problem
Model Number: LER5636EQ0   Brand: Whirlpool   Age: More than 10 years
Dryer will not heat on lower heat cycles. It will heat on higher heat cycles. Could it be the cycling thermostat?
Ads By Google
Related Models
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Whirlpool LER6638DW1 ELECTRIC DRYER
Whirlpool LER6638DZ0 ELECTRIC DRYER
Whirlpool LER6638DZ1 ELECTRIC DRYER
Whirlpool LER6644DQ0 ELECTRIC DRYER
Whirlpool LER6644DQ1 ELECTRIC DRYER
Whirlpool LER6644DZ0 ELECTRIC DRYER
Whirlpool LER6644DZ1 ELECTRIC DRYER
Whirlpool LER6646BN0 ELECTRIC DRYER
Whirlpool LER6646BN1 ELECTRIC DRYER
Whirlpool LER6646BN2 ELECTRIC DRYER
Whirlpool LER6646BW0 ELECTRIC DRYER
Whirlpool LER6646BW1 ELECTRIC DRYER
Whirlpool LER6646BW2 ELECTRIC DRYER
Whirlpool LER6646DN1 ELECTRIC DRYER
Whirlpool LER6646DW1 ELECTRIC DRYER
Whirlpool LER6646PW0 29" ELECTRIC DRYER
Whirlpool LER6646PW1 29" ELECTRIC DRYER
Whirlpool LER6848AN1 ELECTRIC DRYER
Whirlpool LER6848AN2 ELECTRIC DRYER
Whirlpool LER6848AQ2 ELECTRIC DRYER
Whirlpool LER6848AW0 Residential Dryer
Whirlpool LER6848AW1 ELECTRIC DRYER
Whirlpool LER6848AW2 ELECTRIC DRYER
Whirlpool LER6848AZ2 ELECTRIC DRYER
Whirlpool LER7620KQ0 RESIDENTIAL DRYER
Whirlpool LER7620KQ1 ELECTRIC DRYER
Whirlpool LER7620KT0 DRYER
Whirlpool LER7620KT1 ELECTRIC DRYER
Whirlpool LER7620LG0 RESIDENTIAL DRYER
  #2 (permalink)
Old 07-31-2009, 05:45 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Because your cycling thermostat is a bias thermostat I think it is likely the problem. And because it is inexpensive it makes sense to change it out and see if that fixes the problem. Here is the part
Part number: AP3131939
I think you have made the correct call, let's see.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Heating Problem davisroy Dryer Repair 3 11-13-2009 03:57 PM
Whirpool dryer heating problem windsordan Dryer Repair 0 07-30-2009 08:18 AM
Dryer Heating Problem John S Dryer Repair 0 03-06-2008 02:40 PM
Whirpool Dryer heating issues dbreg Dryer Repair 1 01-04-2008 02:24 PM
gas dryer heating problem sakks Dryer Repair 1 09-14-2007 05:45 AM
