Discuss
Intermittent Heat
 in
Dryer Repair
We bought this dryer from a repair shop and it's worked fine for the last year or so. A few
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Intermittent Heat
  #1 (permalink)
Old 07-28-2009, 09:36 PM
Junior Member
docsaintly is on a distinguished road
Default Intermittent Heat
Model Number: dependable care quiet plus II   Brand: Maytag   Age: 1 - 5 years
We bought this dryer from a repair shop and it's worked fine for the last year or so. A few weeks ago it stopped drying clothes. I looked online and some sites suggested it might be a tripped circuit breaker, and that only one leg was working. I went and turned the circuit breaker on and off, went to the dryer and unplugged/replugged it. After this little exercise it started heating again so I thought everything was fine.
This week it started up again, so I got a multimeter and tore into it. Per the guides online, I used the ohm meter function on the parts, and none of them checked in at infinity (which the guides said would indicate they were broken). I turned the dryer on and measured the voltage going to the coil, for a little bit it wasn't reading much (i'm not sure if i was doing it wrong or it just wasn't getting it), and then it heated up and got 240 ( i could visibly see the coil heating up, but also put the voltmeter to it).
The guides i've read say that if the coil gets 240v and it heats up its fine and it's something else, does anyone have any ideas about why it would be intermittent like this? Any ideas what I should test next?
I anxiously await a response (and dry clothes).
Ads By Google
Related Models
Frigidaire DES100CD1 Kel(v2) / Electric Dryer
Frigidaire DES100CW1 Kel(v1) / Electric Dryer
Frigidaire DES100FD2 Kel(v2) / 27 " Dryer
Frigidaire DES100FW2 Kel(v1) / 27 " Dryer
Amana DES11E Commercial Microwaves
Menu Master DES11EA  Commercial Microwaves
Frigidaire DESFL0 Frg(v6) / Electric Dryer
Frigidaire DESFL1 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFL3 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL4 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFW0 Frg(v5) / Electric Dryer
Frigidaire DESFW1 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFW3 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW4 Frg(v5) / 27 " Electric Dryer
Frigidaire DET100KD1 Kel(v4) / 27 " Electric Dryer
Frigidaire DET100KD2 Kel(v4) / 27 " Electric Dryer
Frigidaire DET100KW1 Kel(v3) / 27 " Electric Dryer
Frigidaire DET100KW2 Kel(v3) / 27 " Electric Dryer
Frigidaire DET250K1D Kel(v2) / 27 " Electric Dryer
Frigidaire DET250K1W Kel(v1) / 27 " Electric Dryer
Frigidaire DET400A0D Kel(v8) / Dryer
Frigidaire DET400A0T Kel(v9) / Dryer
Frigidaire DET400A0W Kel(v10) / Dryer
Frigidaire DET400A1D Kel(v9) / Dryer
Frigidaire DET400A1T Kel(v10) / Dryer
Frigidaire DET400A1W Kel(v11) / Dryer
Frigidaire DET400A2D Kel(v9) / Electric Dryer
Frigidaire DET400A2T Kel(v10) / Electric Dryer
Frigidaire DET400A2W Kel(v11) / Electric Dryer
Frigidaire DET400F1D Kel(v12) / Electric Dryer
Frigidaire DET400F1J Kel(v11) / Electric Dryer
Frigidaire DET400F1W Kel(v10) / Electric Dryer
Frigidaire DET400F2D Kel(v11) / Electric Dryer
Frigidaire DET400F2J Kel(v12) / Electric Dryer
Frigidaire DET400F2W Kel(v10) / Electric Dryer
Frigidaire DET400G1D Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G1J Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G1W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G2D Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G2J Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G2W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G3D Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G3J Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G3W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G4D Kel(v6) / 27 " Electric Dryer
Frigidaire DET400G4W Kel(v5) / 27 " Electric Dryer
Frigidaire DET400KD1 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KD2 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KD3 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KW1 Kel(v1) / 27 " Electric Dryer
Frigidaire DET400KW2 Kel(v1) / 27 " Electric Dryer
Frigidaire DET400KW3 Kel(v1) / 27 " Electric Dryer
Maytag DF10AALWH Freezer - Vertical
Maytag DF10ABLWH Freezer - Vertical
Maytag DF10ABLWHT Freezer - Vertical
Maytag DF10BBLWHT  Freezer - Vertical
Amana DF110 Freezer - Chest
Amana DF110A Mwave - Cntrtp / Stand Alone
Amana DF110D Mwave - Cntrtp / Stand Alone
Maytag DF12ABLWH Freezer - Vertical
Maytag DF12ACLWH Freezer - Vertical
Maytag DF12ACLWHT Freezer - Vertical
Maytag DF12BCLWHT  Freezer - Vertical
Maytag DF12H  Freezer - Vertical
Maytag DF12J Freezer - Vertical
Maytag DF15AAL-WH Freezer - Vertical
Maytag DF15ABLWH Freezer - Vertical
Maytag DF15ACLWH Freezer - Vertical
Maytag DF15ADLWH Freezer - Vertical
Maytag DF15ADLWHT Freezer - Vertical
Maytag DF15ASLWH Freezer - Vertical
Maytag DF15ATLWH Freezer - Vertical
Maytag DF15ATLWHT Freezer - Vertical
Maytag DF15AUMALT Freezer - Vertical
Maytag DF15AUMWHT Freezer - Vertical
Maytag DF15BDLWHT  Freezer - Vertical
Maytag DF15BE  Freezer - Vertical
Maytag DF15BPB  Freezer - Vertical
Maytag DF15BTLWHT  Freezer - Vertical
Maytag DF15BUMALT  Freezer - Vertical
Maytag DF15BUMWHT Freezer - Vertical
Maytag DF15H Freezer - Vertical
Maytag DF15HG Freezer - Vertical
Maytag DF15HS Freezer - Vertical
Maytag DF15HX Freezer - Vertical
Maytag DF15J Freezer - Vertical
Maytag DF15JG Freezer - Vertical
Amana DF160 Freezer - Chest
Amana DF160-1 Freezer - Chest
Amana DF160A Freezer - Chest
Amana DF170 Freezer - Chest
Maytag DF17AALWH Freezer - Vertical
Maytag DF17ABLWH Freezer - Vertical
Maytag DF17ACLWH Freezer - Vertical
Maytag DF17ACLWHT Freezer - Vertical
Maytag DF17BCLWHT  Freezer - Vertical
Maytag DF17BPB  Freezer - Vertical
Amana DF180 Freezer - Chest
Amana DF180A Mwave - Cntrtp / Stand Alone
Amana DF180B Mwave - Cntrtp / Stand Alone
Maytag DF20AALWH Freezer - Vertical
Maytag DF20ABLWH Freezer - Vertical
Maytag DF20ACLWH Freezer - Vertical
Maytag DF20ACLWHT Freezer - Vertical
Maytag DF20BCLWHT  Freezer - Vertical
Maytag DF20H  Freezer - Vertical
Maytag DF20HX  Freezer - Vertical
Maytag DF20J Freezer - Vertical
Amana DF220 Freezer - Chest
Amana DF220A Freezer - Chest
Amana DF240 Freezer - Chest
Amana DF240A Mwave - Cntrtp / Stand Alone
Amana DF240B Mwave - Cntrtp / Stand Alone
Amana DF90 Freezer - Chest
Amana DF90A Freezer - Chest
Maytag DFB1100AAX Disposal
Maytag DFB1100ABX Disposal
  #2 (permalink)
Old 07-31-2009, 09:49 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Doc
If your machine is operating intermittently then all of your electric components should be ok.
I would check all of the wires, including the heating element for a loose connection or a short, and check the connection where the wires come into the connection block. They should be very tight.
Good luck, hope this helps solve it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Intermittent Problem w/ Heat rjl41 Dryer Repair 0 12-09-2009 04:48 PM
Dryer intermittent to no heat edm812 Dryer Repair 6 07-30-2009 07:03 PM
Intermittent heat fxn001 Dryer Repair 1 07-13-2009 01:18 PM
Intermittent dryer heat edm812 Dryer Repair 4 04-15-2009 06:08 AM
Intermittent Heat ASinSeattle Dryer Repair 0 12-22-2008 08:20 PM
