Discuss
thump noise
 in
Dryer Repair
Hello, I have replaced a belt in this dryer. The tensioner is a non pulley type that is indented, is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » thump noise
  #1 (permalink)
Old 07-28-2009, 05:54 PM
Junior Member
ptc123 is on a distinguished road
Default thump noise
Model Number: LEN2000JQ1   Brand: Whirlpool   Age: 1 - 5 years
Hello, I have replaced a belt in this dryer. The tensioner is a non pulley type that is indented, is this wear or by design? Also the upper right drum support disc is able to move back and forth along the lenght of it's shaft were as the left disc does not. All clips are in place. I checked the drum for a potential cause for the noise but it is clear. Should that right disc be able to move like that? How tight should the drum seals be? Thank you for your attention, PTC
Ads By Google
Related Models
Whirlpool LEN2000JQ1
Whirlpool LEN2000JQ2
Whirlpool LEN2000JT0
Whirlpool LEN2000JT1
Whirlpool LEN2000JT2
Whirlpool LEN2000KQ0
Whirlpool LEN2000KQ1 29"electric Dryer
Whirlpool LEN2000KQ2 29"electric Dryer
Whirlpool LEN2000KT0
Whirlpool LEN2000KT1 29"electric Dryer
Whirlpool LEN2000LG0
Whirlpool LEN2000LG1 29"electric Dryer
Whirlpool LEN2000LW0
Whirlpool LEN2000LW1 29"electric Dryer
Whirlpool LEN2000PG0 29"electric Dryer
Whirlpool LEN2000PG1 29"electric Dryer
Whirlpool LEN2000PW0 29"electric Dryer
Whirlpool LEN2000PW1 29"electric Dryer
Whirlpool LEN3434AW0
Whirlpool LEN3624BN0
Whirlpool LEN3624BN1
Whirlpool LEN3624BN2
Whirlpool LEN3624BW0
Whirlpool LEN3624BW1
Whirlpool LEN3624BW2
Whirlpool LEN3634DW0
Whirlpool LEN3634DW1
Whirlpool LEP6646AN0
Whirlpool LEP6646AN1
Whirlpool LEP6646AN2
Whirlpool LEP6646AW0
Whirlpool LEP6646AW1
Whirlpool LEP6646AW2
Whirlpool LEP6848AN0
Whirlpool LEP6848AN1
Whirlpool LEP6848AN2
Whirlpool LEP6848AW0
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
Whirlpool LEP7858AW1
Whirlpool LEP7858AW2
Whirlpool LEP7858AZ2
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
  #2 (permalink)
Old 07-31-2009, 09:45 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Ptc
This is hard to diagnose from afar, because the way we try to find out what is wrong is to listen to the source, and well, we cannot do that here.
I suspect you drum is not seated correctly after you took off the front to replace the belt, so I would take it apart again and put it back together. The fit should be pretty tight. If this does not solve it, replacing the rollers would be the next act.
Here is what your tensioner should look like
Part number: AP2911909
Good luck, hope this helps.
__________________
  #3 (permalink)
Old 07-31-2009, 12:18 PM
Junior Member
Default
Thank you for the response. The tensioner does not look like the one in your image. It is similar in the spring part but does not have a roller. Instead it is a metalic half moon shape with a silicon strip the the back of the belt runs over. I was wondering if the indentation in the tensioner head was by design or is it a sign of wear? The other question I have is the upper(right) support wheel travels the full lenght of the shaft it is on, is that supposed to be so? Thanks for your help, PTC
  #4 (permalink)
Old 07-31-2009, 12:27 PM
Senior Expert
APP Volunteer
Default
Gosh, I don't know. (How's that for honesty?)
The tensioner in the picture is the one I am familiar with, it is the typical Whirlpool part and it is the one the specs say should be in your machine.
Why don't you change it out and see if it cures your problem.
__________________
  #5 (permalink)
Old 07-31-2009, 02:40 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
You can replace the tensioner you have with the one in the picture. Yours is that way by design, in order to reduce manufacturing costs. For your thumping noise, you may want to check for a loose baffle inside the tumbler (they're attached with screws from the outside of the tumbler). Also a common cause of thumping noises is wear in the support rollers.
  #6 (permalink)
Old 08-01-2009, 07:44 AM
Junior Member
Default re: thump noise
sidfink43, Promptness and honesty are traits I greatly admire! Thank you for your advice. The tensioner is probably not part of the noise problem and the support wheels seem to be in very good shape. The noise is not critical but being around machines like I have makes me wonder.
magician59, I made a quick survey of the baffles the first time around and found one alittle loose which also had change inside it,so I tightened it. I will check them more closely and see if that helps. Thank you both again for your able assistance, you are a valued resource! PTC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer making load thump noise in spin cycle tngrafix Washer Repair 4 01-08-2010 10:05 AM
rumble thump sound garykranz Dryer Repair 1 03-03-2009 02:30 AM
loud thump from my maytag washer takers44 Washer Repair 0 11-29-2008 12:07 PM
Kenmore 90 srs thump/grind heard when braking down from spin cycle toddly Washer Repair 4 03-02-2008 04:46 AM
Thump in dryer sc2001hd Dryer Repair 1 10-31-2007 07:46 AM
