| » drum turning but not heat |
Model Number: fgq1442es0 Brand: Frigidaire Age: 1 - 5 years
My drum is turning but I have no heat. The owners manual is saying that there are 2 house fuses in the dryer circuit that I should check first, but I can't seem to locate them can someone help please?
Thank you Ads By Google Related Models |
Take off the lower front panel and you should see thermostats/fuses. Also, lift up the top (it should release by inserting a screw driver or putty knife in the gap between the top and front at the edges) and you should access a safety thermostate.
You will need to test these for continuity with a meter, and you should find your problem. If this is electric, make sure you have 120 volts coming to each side of the connection block. Good luck.
__________________
| Display Modes | |
| drum not turning | ron fleming | Dryer Repair | 3 | 02-19-2010 06:56 AM |
| Drum stopped turning | swkitty | Dryer Repair | 3 | 02-18-2010 04:25 PM |
| drum not turning | sharon warfel | Dryer Repair | 2 | 05-28-2009 05:52 AM |
| Gas Dryer still blowing heat - drum not turning | cathylyons | Dryer Repair | 2 | 09-29-2008 12:56 PM |
| not turning of the drum | scott glynn | Washer Repair | 1 | 10-12-2007 10:51 AM |
