Older Kenmore dryer not heating
Dryer Repair
I've already fixed the problem, but wanted to post in case anyone else had the same issue. The dryer was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Older Kenmore dryer not heating
  #1 (permalink)
Old 02-22-2012, 07:18 AM
Junior Member
jttaylor is on a distinguished road
Default Older Kenmore dryer not heating
Model Number: 11096273100   Brand: Kenmore   Age: More than 10 years
I've already fixed the problem, but wanted to post in case anyone else had the same issue. The dryer was not heating (heating element did not come on).
The thermal cut-off tested bad (open) so I replaced it and the hi-limit thermostat (the two parts come together as a kit). I'm not sure if the parts were bad or something made it overheat. The venting is fine and I don't see anything else wrong.
Anyway, it's been running well for a while now.
Related Models
Kenmore 11096273100 DRYER FEATURE SHEET
Kenmore 11096273600 DRYER FEATURE SHEET
Kenmore 11096273800 DRYER FEATURE SHEET
Kenmore 11096274100 DRYER FEATURE SHEET
Kenmore 11096274600 DRYER FEATURE SHEET
Kenmore 11096274800 DRYER FEATURE SHEET
Kenmore 11096278100 DRYER FEATURE SHEET
Kenmore 11096278800 DRYER FEATURE SHEET
Kenmore 11096280100 DRYER FEATURE SHEET
Kenmore 11096280600 DRYER FEATURE SHEET
Kenmore 11096280800 DRYER FEATURE SHEET
Kenmore 11096281100 DRYER FEATURE SHEET
Kenmore 11096281800 DRYER FEATURE SHEET
Kenmore 11096282100 DRYER FEATURE SHEET
Kenmore 11096282800 DRYER FEATURE SHEET
Kenmore 11096283100 DRYER FEATURE SHEET
Kenmore 11096283110 ELECTRIC DRYER
Kenmore 11096283800 DRYER FEATURE SHEET
Kenmore 11096283810 ELECTRIC DRYER
Kenmore 11096284100 DRYER FEATURE SHEET
Kenmore 11096284110 ELECTRIC DRYER
Kenmore 11096284800 DRYER FEATURE SHEET
Kenmore 11096284810 ELECTRIC DRYER
Kenmore 11096291100 DRYER FEATURE SHEET
Kenmore 11096291110 ELECTRIC DRYER
Kenmore 11096291800 DRYER FEATURE SHEET
Kenmore 11096291810 ELECTRIC DRYER
Kenmore 11096292100 DRYER FEATURE SHEET
Kenmore 11096292110 ELECTRIC DRYER
Kenmore 11096292800 DRYER FEATURE SHEET
Kenmore 11096292810 ELECTRIC DRYER
Kenmore 11096293100 DRYER FEATURE SHEET
Kenmore 11096293110 ELECTRIC DRYER
Kenmore 11096293500 DRYER FEATURE SHEET
Kenmore 11096293510 ELECTRIC DRYER
Kenmore 11096293800 DRYER FEATURE SHEET
Kenmore 11096293810 ELECTRIC DRYER
Kenmore 11096310100 ELECTRIC DRYER
Kenmore 11096320100 ELECTRIC DRYER
Kenmore 11096350100 ELECTRIC DRYER
Kenmore 11096363100 ELECTRIC DRYER
Kenmore 11096363800 ELECTRIC DRYER
Kenmore 11096364100 ELECTRIC DRYER
Kenmore 11096364800 ELECTRIC DRYER
Kenmore 11096374200 ELECTRIC DRYER
Kenmore 11096374210 ELECTRIC DRYER
Kenmore 11096375100 ELECTRIC DRYER
Kenmore 11096375800 ELECTRIC DRYER
Kenmore 11096418100 DRYER FEATURE SHEET
Kenmore 11096418800 DRYER FEATURE SHEET
Kenmore 11096428100 DRYER FEATURE SHEET
Kenmore 11096428800 DRYER FEATURE SHEET
Kenmore 11096429100 DRYER SPECIFICATIONS
Kenmore 11096429800 DRYER SPECIFICATIONS
Kenmore 11096468100 DRYER-FEATURE SHEET
Kenmore 11096468800 DRYER-FEATURE SHEET
Kenmore 11096469100 DRYER-FEATURE SHEET
Kenmore 11096469800 DRYER-FEATURE SHEET
Kenmore 11096478100 DRYER- FEATURE SHEET
Kenmore 11096478800 DRYER- FEATURE SHEET
Kenmore 11096502100 ELECTRIC DRYER
Kenmore 11096502110 ELECTRIC DRYER
Kenmore 11096502800 ELECTRIC DRYER
Kenmore 11096502810 ELECTRIC DRYER
Kenmore 11096510100 ELECTRIC DRYER
Kenmore 11096510110 ELECTRIC DRYER
Kenmore 11096510120 ELECTRIC DRYER
Kenmore 11096511100 ELECTRIC DRYER
Kenmore 11096511110 ELECTRIC DRYER
Kenmore 11096511120 ELECTRIC DRYER
Kenmore 11096512200 ELECTRIC DRYER
Kenmore 11096512210 ELECTRIC DRYER
Kenmore 11096520100 Residential Dryer
Kenmore 11096520110 ELECTRIC DRYER
Kenmore 11096520120 ELECTRIC DRYER
Kenmore 11096529100 Residential Dryer
Kenmore 11096529110 ELECTRIC DRYER
Kenmore 11096529120 ELECTRIC DRYER
Kenmore 11096529130 ELECTRIC DRYER
Kenmore 11096529800 ELECTRIC DRYER
Kenmore 11096529810 ELECTRIC DRYER
Kenmore 11096529820 ELECTRIC DRYER
Kenmore 11096529830 ELECTRIC DRYER
Kenmore 11096530100 ELECTRIC DRYER
Kenmore 11096530110 ELECTRIC DRYER
Kenmore 11096550100 ELECTRIC DRYER
Kenmore 11096550110 ELECTRIC DRYER
Kenmore 11096550120 ELECTRIC DRYER
Kenmore 11096551200 ELECTRIC DRYER
Kenmore 11096551210 ELECTRIC DRYER
Kenmore 11096551220 ELECTRIC DRYER
Kenmore 11096551230 ELECTRIC DRYER
Kenmore 11096560100 Residential Dryer
Kenmore 11096560110 ELECTRIC DRYER
Kenmore 11096560120 Dryer
Kenmore 11096560200 ELECTRIC DRYER
Kenmore 11096560210 ELECTRIC DRYER
Kenmore 11096560800 Residential Dryer
Kenmore 11096560810 ELECTRIC DRYER
Kenmore 11096560820 Dryer
Kenmore 11096561100 ELECTRIC DRYER
Kenmore 11096561110 ELECTRIC DRYER
Kenmore 11096561120 Dryer
Kenmore 11096561210 ELECTRIC DRYER
Kenmore 11096561220 Dryer
Kenmore 11096561230 ELECTRIC DRYER
Kenmore 11096561420 Dryer
Kenmore 11096561430 ELECTRIC DRYER
Kenmore 11096561800 ELECTRIC DRYER
Kenmore 11096561810 ELECTRIC DRYER
Kenmore 11096561820 Dryer
Kenmore 11096562200 ELECTRIC DRYER
Kenmore 11096562500 RESIDENTIAL DRYER
Kenmore 11096562501 RESIDENTIAL DRYER
Kenmore 11096563100 ELECTRIC DRYER
Kenmore 11096563110 ELECTRIC DRYER
Kenmore 11096563120 ELECTRIC DRYER
Kenmore 11096563800 ELECTRIC DRYER
Kenmore 11096563810 ELECTRIC DRYER
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
older ge oven not heating properly kris23 Oven Repair (including Ranges and Cooktops) 2 02-13-2012 08:39 PM
Older Kenmore Dryer Sierra Steve Dryer Repair 0 10-19-2011 02:37 PM
Older Oven not heating correctly cougar1963 Oven Repair (including Ranges and Cooktops) 0 09-16-2010 01:45 PM
Older Maytag Gas Oven Not heating-assitance please ccarey8186 Oven Repair (including Ranges and Cooktops) 0 01-10-2010 11:23 AM
Older Gas Oven not heating up enough Meg70 Oven Repair (including Ranges and Cooktops) 1 02-11-2008 01:13 PM
