| » Dryer doesn't stop |
Model Number: MDG7400AWW Brand: Maytag Age: 1 - 5 years
for the last 4-5 months My dryer doesn't seem to be stopping on time. One time it when on for about 2 hours before it shut off. it seems like the moisture sensor is not working correctly and keeps running even though the clothes are dry. Even when I use non - intellidry settings which is just a timer it wouldn't stop even when the time run outs. Now I have to keep an eye on the dryer otherwise it would go on drying for hours and it already raise my gas bill by a big amount. Anyone have any idea what might be causing this? is it the sensor? if so can how do I find out how to replace it? Any help would be much appreciated
Well, most of the posts here are that the dryer won't start, so at least you have that.
Given that this happens in the timed dry cycle, that would suggest the timer is the problem rather than any moisture sensing system. Replacing it should (but not certainly) fix your problem. Good luck, let us know what you do and how it turns out.
__________________
It looks there are two different timers that are made for your model, depending upon when your model was made. This is not unusual for this brand.
I would call APP or whatever other parts supplier you want to use (I think APP will be the least expensive, andno, we do not work for them) on Monday and if you give them your model and serial number they should get you the right one. Good luck with this.
__________________
| Display Modes | |
| dryer does not stop | chuck465 | Dryer Repair | 3 | 11-22-2009 06:00 AM |
| Dryer does not Stop! | familylaundry | Dryer Repair | 2 | 07-29-2009 04:22 PM |
| Dryer does not stop | dherrick | Dryer Repair | 6 | 04-23-2009 04:58 PM |
| dryer will not stop | freemans | Dryer Repair | 0 | 09-06-2008 10:42 PM |
| Dryer Won't Stop | caligal64 | Dryer Repair | 11 | 12-07-2007 08:29 PM |
