Discuss
electric Dryer not heating
 in
Dryer Repair
Whirlpool electric dryer not heating. Assumed it was heating element and replaced. Dryer is still not heating. Any other ideas
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » electric Dryer not heating
  #1 (permalink)
Old 07-28-2009, 11:52 AM
Junior Member
RJ Trucks is on a distinguished road
Default electric Dryer not heating
Model Number: le5200xt   Brand: Whirlpool   Age: More than 10 years
Whirlpool electric dryer not heating. Assumed it was heating element and replaced. Dryer is still not heating. Any other ideas on what could be wrong. This has been a very good dryer and I don't want to replace.
Thanks rj trucks
Ads By Google
Related Models
Whirlpool LE5200XTF0
Whirlpool LE5200XTG0
Whirlpool LE5200XTM0
Whirlpool LE5200XTN0
Whirlpool LE5200XTN1
Whirlpool LE5200XTW0
Whirlpool LE5200XTW1
Whirlpool LE5320XTF0
Whirlpool LE5320XTG0
Whirlpool LE5320XTM0
Whirlpool LE5320XTN0
Whirlpool LE5320XTW0
Whirlpool LE5530XKW0
Whirlpool LE5530XKW1
Whirlpool LE5530XKW2
Whirlpool LE5530XMW0
Whirlpool LE5530XMW1
Whirlpool LE5530XMW2
Whirlpool LE5530XPW0
Whirlpool LE5530XSW0
Whirlpool LE5530XSW1
Whirlpool LE5535XPW0
Whirlpool LE5550XTG0
Whirlpool LE5550XTN0
Whirlpool LE5550XTW0
Whirlpool LE5600XKW0
Whirlpool LE5600XMW0
Whirlpool LE5600XPW0
Whirlpool LE5600XSW0
Whirlpool LE5600XSW1
Whirlpool LE5605XPW0
Whirlpool LE5650XKW0
Whirlpool LE5650XKW1
Whirlpool LE5650XMW0
Whirlpool LE5650XMW1
Whirlpool LE5650XMW2
Whirlpool LE5700XKW0
Whirlpool LE5700XKW1
Whirlpool LE5700XMW0
Whirlpool LE5700XMW1
Whirlpool LE5700XMW2
Whirlpool LE5700XPW0
Whirlpool LE5700XSW0
Whirlpool LE5705XPW0
Whirlpool LE5705XPW1
Whirlpool LE5720XPW0
Whirlpool LE5720XSG1
Whirlpool LE5720XSW0
Whirlpool LE5720XSW1
Whirlpool LE5725XPW0
Whirlpool LE5750XFW0
Whirlpool LE5750XKW0
Whirlpool LE5750XKW1
Whirlpool LE5750XKW2
Whirlpool LE5750XMW0
Whirlpool LE5750XMW1
Whirlpool LE5760XSN1
Whirlpool LE5760XSW0
Whirlpool LE5760XSW1
Whirlpool LE5770XWN0
Whirlpool LE5770XWW0
Whirlpool LE5780XKW0
Whirlpool LE5780XKW1
Whirlpool LE5780XMW0
Whirlpool LE5780XMW1
Whirlpool LE5780XMW2
Whirlpool LE5790XMW0
Whirlpool LE5790XMW1
Whirlpool LE5790XPW0
Whirlpool LE5790XSW0
Whirlpool LE5790XSW1
Whirlpool LE5795XMW0
Whirlpool LE5795XPW0
Whirlpool LE5795XPW1
Whirlpool LE5800XKW0
Whirlpool LE5800XKW1
Whirlpool LE5800XMW0
Whirlpool LE5800XMW1
Whirlpool LE5800XMW2
Whirlpool LE5800XPW0
Whirlpool LE5800XPW1
Whirlpool LE5800XSW0
Whirlpool LE5800XSW1
Whirlpool LE5800XSW2
Whirlpool LE5800XSW3
Whirlpool LE5805XPW0
Whirlpool LE5810XPW0
Whirlpool LE5900XSW0
Whirlpool LE5920XKW0
Whirlpool LE5920XKW1
Whirlpool LE5920XMW0
Whirlpool LE5920XMW1
Whirlpool LE5920XMW2
Whirlpool LE5950XSW0
Frigidaire LE600AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD3 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW3 Wwh(v1) / 27 " Laundry Center
Whirlpool LE6055XSW0
Whirlpool LE6055XSW1
Whirlpool LE6090XSW0
Whirlpool LE6090XSW1
Whirlpool LE6090XTG0
Whirlpool LE6090XTN0
Whirlpool LE6090XTW0
Whirlpool LE6098XSW0
Whirlpool LE6098XSW1
Whirlpool LE6098XTF0
Whirlpool LE6098XTG0
Whirlpool LE6098XTG1
Whirlpool LE6098XTM0
Whirlpool LE6098XTN0
Whirlpool LE6098XTN1
Whirlpool LE6098XTW0
  #2 (permalink)
Old 07-30-2009, 05:54 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
When you replaced the heating element you should have seen thermal fusesand thermostats. Check them for continuity, particularly the thermal fuse. Make sure the dryer is thoroughly cleaned of lint, particularly in the exhaust vent and blower
Before doing that, check to see that you are getting 120 volts to each side of the connection block. Then unplug the machine to do the other checks.
Good luck.
__________________
  #3 (permalink)
Old 04-12-2010, 09:35 PM
Junior Member
crystalskarsvog is on a distinguished road
Default dryer wont heat
my sister in law gave me and my husband a washer and dryer. but the dryer went out and she had some one come look at and they said it was the thurmistat and they replaced those but it still didnt heat up so she thought it was the heating element and we got the part and replaced it and its still not heating up its frustrating cuz we really need it with 6 ppl in the same house and a baby on the way.. HELP!!!!!
  #4 (permalink)
Old 04-13-2010, 04:27 AM
Senior Expert
APP Volunteer
Default
If you will post the brand and model number of the machine someone should be able to help you. Please start a new thread and describe in as much detail as you think appropriate how the machine is operating. I am assuming that it runs but no heat comes out, and that this happens in all cycles.
__________________
  #5 (permalink)
Old 04-13-2010, 04:50 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
__________________
  #6 (permalink)
Old 04-13-2010, 08:45 AM
Junior Member
all i know right now with the dry is that it spins but its not drying and the thermistats have been replace along with the heating element. its a whirlpool dryer and old one at that the model number is LE5720XSW1. it just suks that i wont dry its a good dry when it worked i just cant find anything online and me and my husband have no money to get it looked at or buy something for it.
  #7 (permalink)
Old 04-14-2010, 02:23 AM
Senior Expert
APP Volunteer
Default
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203393987.pdf
You could always borrow a meter.
As sidfink43 said you have to check the power first, could be there is nothing wrong with the dryer. The motor and timer run off half the line (120 volts) but the heater requires the full 240 volts.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Be sure to disconnect one side of and device you are measuring this prevents reading an alternate/parallel circuit path. Also use your most sensitive ohms scale.
There is a good Sticky at the beginning of this forum on meter usage.
__________________
  #8 (permalink)
Old 09-09-2010, 08:53 AM
Junior Member
juanrodman is on a distinguished road
Default Similar Problem-Electric Dryer Won't Heat
I have a Whirlpool model LEC8858DQ0. I went through the complete sequence with a meter and find no problem with power at wall or terminal strip, and continuity on thermostats, thermal fuse, or heating coil. The lint path is clean and I am stumped! Thanks for the tremendous help!
  #9 (permalink)
Old 09-09-2010, 08:58 AM
Senior Expert
APP Volunteer
Default
juanrodman
Please start your own thread using Post New Topic in the dryer section.
It will just get confusing trying to troubleshoot 2 different models even if the symptoms are the same
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Dryer not heating glopez01 Dryer Repair 1 12-07-2009 03:59 PM
Electric Dryer Not Heating bkeiger Oven Repair (including Ranges and Cooktops) 3 08-01-2009 07:56 AM
Electric dryer not heating mo723 Dryer Repair 4 06-04-2009 03:10 PM
electric dryer not heating up ltrain Dryer Repair 1 01-12-2009 05:39 AM
Electric Dryer Not Heating doutre Dryer Repair 3 09-30-2008 07:53 PM
