Discuss
Speed Queen Electric Dryer Pops Breaker
 in
Dryer Repair
When the main control knob/timer knob is in the off position the dryer can be plugged in and the dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Speed Queen Electric Dryer Pops Breaker
  #1 (permalink)
Old 07-28-2009, 10:29 AM
Junior Member
nomoney is on a distinguished road
Default Speed Queen Electric Dryer Pops Breaker
Brand: Speed Queen   Age: More than 10 years
When the main control knob/timer knob is in the off position the dryer can be plugged in and the dryer does not blow the main fuse box breaker. However whenever the knob is turned to anywhere else except the multiple off positions it pops the breaker immediately.
Mike
  #2 (permalink)
Old 07-28-2009, 12:50 PM
Junior Member
Default More information.
The dryer is a Speed Queen Heavy Duty Dryer Model : HE4503L Serial : S3M76568
I've taken a few measurements on the power input where the power cord attach's to the unit.
Between the red and the white (white is also ground green) wires I measure 2.4K ohms and between all others it appears high resistance. When I move the control to the off setting the resistance is high between the red and the white wires also.
I check the continuity on the door switch and the start switch both were good.
I did reset the breaker a couple of times. It does appear that only one side is breaking but it does reset.
BTW Last week I installed a new drum roller because one of the old ones wore out.
If you can help me take some measurements to troubleshoot this old dryer I would appreciate it.
Mike
  #3 (permalink)
Old 07-28-2009, 01:33 PM
Junior Member
Default Just found this comment with your search function
comment "had a dryer trip a breaker once, it was a bad roller making it hard for the motor to turn the drum if its an older dryer it might be the problem"
Could it be that the new drum roller is creating more resistance to the drum than previously and that is what is causing the fault?
After I replaced the drum roller I turned on the machine and it worked normally for my 2 minute empty test run. The dryer failed the very next time my wife tried to use it with clothes in it. Now it fails empty and every time the timer is set to any thing other than "off"
Mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Speed Queen Dryer won't ingnite mastoops Dryer Repair 0 12-06-2009 10:18 PM
GE Electric Convection Oven Pops Circuit Breaker during Cleaning Cycle and every sinc RA6102 Oven Repair (including Ranges and Cooktops) 0 10-06-2009 09:24 AM
Speed Queen gas dryer Flor Dryer Repair 0 09-25-2009 10:41 AM
Speed Queen dryer thomk44 Dryer Repair 1 03-10-2009 06:10 PM
Breaker pops after 1 minute on roper dryer gary1167 Dryer Repair 2 03-19-2008 05:58 PM
