My Roper Dryer door is broken and I have to lift it to start, but the operation stops immediately afterwards. Do I need a door switch kit or the door handle needs to be replaced?
assuming that all the door hinges are in good shape and that the door is attached properly the it is more likely the door switch need replacing
