How do you remove the lint chute? When I tried to pull out the chute after removing the 6 screws at the top and bottom I found there was interference from a sheet metal piece at the top of the rear of the dryer. Pulling out the chute would have made cleaning much easier.
If there is not room to remove it from the back it will have to come out the top.
