| » Dryer starts then stops when drum is manually moved |
Model Number: MDE308DAYW Brand: Maytag Age: 5 - 10 years
Hello,
I have a Maytag electric dryer. It will start and run a complete cycle (on any of the three dryer settings) and then on the next load, it will stop after 2 - 5 minutes. At first I thought it was the timer, then my wife noticed that the light wasn't coming on when it was in it's non-start mode. I noticed that when I move the drum, the light can be made to come back on, and it will run...sometimes. When it does run, it does dry the clothes. Could it be the belt and/or belt pulley? Any ideas would be appreciated. Thank you. Ads By Google Related Models |
Most likely the problem is with door switch. With power off raise the top and check for continuity between white and yellow/black wires with door closed.
The door switch Part number: AP4319999 Here is the breakdown diagram of the dryer Replacement parts for Maytag MDE308DAYW DRYER- ELE | AppliancePartsPros.com |
| Display Modes | |
| Dryer Starts and then Stops | Jbee14 | Dryer Repair | 2 | 09-23-2011 02:15 AM |
| Dryer starts then stops | Earl w | Dryer Repair | 1 | 08-16-2010 03:04 AM |
| Dryer squeeks when drum starts | dostroski | Dryer Repair | 1 | 08-21-2009 09:50 AM |
| GE Gas Dryer starts & stops, etc. | danjaxson | Dryer Repair | 0 | 03-15-2009 12:11 PM |
| Drum not turning, starts but stops when button is released | Lynne Pfortmiller | Dryer Repair | 0 | 05-26-2008 10:25 AM |
