Discuss
Dryer problems/questions
 in
Dryer Repair
My dryer has (2) recognizable problems, that I don't know where to start in diagnosing which part(s) need
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer problems/questions
  #1 (permalink)
Old 01-07-2008, 06:59 PM
jamesb1034 jamesb1034 is offline
Junior Member
jamesb1034 is on a distinguished road
Question Dryer problems/questions
Model Number: lgr3624eq2   Brand: Whirlpool   Age: 1 - 5 years
My dryer has (2) recognizable problems, that I don't know where to start in diagnosing which part(s) need replacement:
Problem 1: Viewing from the front panel plug, when I start the dryer, I can see the glow plug begin to light. Sometimes the burner will light, most of the time it will not. Sometimes, when lit, it stays lit for anywhere from a few seconds to the duration of the dry time. Needless to say, something isn't working properly, as most of the time, after the glow plug lights up, the dryer just continues to tumble air dry, without any heat. I don't know if it's the coils (both or 1), spring, the entire gas valve, radiant sensor, or something else?
Problem 2: Just prior to the dryer having problem #1, the dryer, when set on the automatic "very dry" (high heat) - not timed - the dryer would continue to run for hours - one time it ran over-night and in the morning the clothes were extremely hot, as the dryer ran 8+ hours. Is there some other sensor that could've went bad that measures moisture of the clothes being dried, to use this sensor?
Any help would be greatly appreciated.
Thanks,
Adam (jamesb1034@aol.com)
Related Models
Whirlpool LGR3624EQ2
Whirlpool LGR3624JQ0
Whirlpool LGR3624JQ1
Whirlpool LGR3624JQ3 29" Gas Dryer
Whirlpool LGR3624PQ0 29" Gas Dryer
Whirlpool LGR3624PQ1 29" Gas Dryer
Whirlpool LGR3634EW0
Whirlpool LGR3634EW1
Whirlpool LGR3634EW2
Whirlpool LGR3634EW3
Whirlpool LGR3634JW0
Whirlpool LGR3634JW1
Whirlpool LGR3634JW2
Admiral LGR3725ADC Range - S/c F/s Gas
Whirlpool LGR4434AN0
Whirlpool LGR4434AN1
Whirlpool LGR4434AQ0
Whirlpool LGR4434AQ1
Whirlpool LGR4434AW0
Whirlpool LGR4434AW1
Whirlpool LGR4436AN0
Whirlpool LGR4436AW0
Whirlpool LGR4600PQ0 29" Gas Dryer
Whirlpool LGR4600PQ1 29" Gas Dryer
Whirlpool LGR4624BN0
Whirlpool LGR4624BN1
Whirlpool LGR4624BN2
Whirlpool LGR4624BQ0
Whirlpool LGR4624BQ1
Whirlpool LGR4624BQ2
Whirlpool LGR4624BW0
Whirlpool LGR4624BW1
Whirlpool LGR4624BW2
Whirlpool LGR4624DQ0
Whirlpool LGR4624DQ1
Whirlpool LGR4624DZ0
Whirlpool LGR4624DZ1
Whirlpool LGR4634BQ0
Whirlpool LGR4634BQ1
Whirlpool LGR4634BQ2
Whirlpool LGR4634DQ0
Whirlpool LGR4634DQ1
Whirlpool LGR4634DZ0
Whirlpool LGR4634EQ0
Whirlpool LGR4634EQ1
Whirlpool LGR4634EQ2
Whirlpool LGR4634EQ3
Whirlpool LGR4634EW0
Whirlpool LGR4634EZ0
Whirlpool LGR4634EZ1
Whirlpool LGR4634EZ2
Whirlpool LGR4634EZ3
Whirlpool LGR4634JQ0
Whirlpool LGR4634JQ1
Whirlpool LGR4634JQ2
Whirlpool LGR4634JQ3 29" Gas Dryer
Whirlpool LGR4634JT0
Whirlpool LGR4634JT1
Whirlpool LGR4634JT2
Whirlpool LGR4634JT3 29" Gas Dryer
Whirlpool LGR4634JZ0
Whirlpool LGR4634JZ1
Whirlpool LGR4634PQ0 29" Gas Dryer
Whirlpool LGR4634PQ1 29" Gas Dryer
Whirlpool LGR4634PT0 29" Gas Dryer
Whirlpool LGR4634PT1 29" Gas Dryer
Whirlpool LGR5434AN0
Whirlpool LGR5434AW0
Whirlpool LGR5600HQ0
Whirlpool LGR5600HZ0
Whirlpool LGR5600JQ0
Whirlpool LGR5600JQ1
Whirlpool LGR5600JT0
Whirlpool LGR5600JT1
Whirlpool LGR5620KQ0
Whirlpool LGR5620KQ1
Whirlpool LGR5620KQ2 29"gas Dryer
Whirlpool LGR5624BN0
Whirlpool LGR5624BN1
Whirlpool LGR5624BN2
Whirlpool LGR5624BW0
Whirlpool LGR5624BW1
Whirlpool LGR5624BW2
Whirlpool LGR5624DQ0
Whirlpool LGR5624DQ1
Whirlpool LGR5624DW1
Whirlpool LGR5624DZ0
Whirlpool LGR5624DZ1
Whirlpool LGR5634AN0
Whirlpool LGR5634AQ0
Whirlpool LGR5634AQ1
Whirlpool LGR5634AQ2
Whirlpool LGR5634AW0
Whirlpool LGR5634DQ1
Whirlpool LGR5634EQ0
Whirlpool LGR5634EZ0
Whirlpool LGR5634LQ0
Whirlpool LGR5635LQ0 29"gas Dryer
Whirlpool LGR5635LQ1 29"gas Dryer
Whirlpool LGR5636DW0
Whirlpool LGR5636DW1
Whirlpool LGR5636EQ0
Whirlpool LGR5636EQ1
Whirlpool LGR5636EQ2
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
Whirlpool LGR5636LQ0
Whirlpool LGR5636LQ1 29"gas Dryer
  #2 (permalink)
Old 04-27-2008, 01:50 PM
lrbarrios lrbarrios is offline
Junior Member
lrbarrios is on a distinguished road
Default Same exact problem
Adam, did you ever get your problem resolved? I noticed the same problem with the dryer running for hours on mine too. Shortly after that problem began, it quit heating. I thought the 'no heat' problem might be the heating element (I've had that problem before on another dryer... simple fix). But now, I'm looking up my model # and it seems like this is supposed to be a gas dryer!! What the heck? Perhaps this dryer was converted by the previous owner. Needless to say, I'm probably going to have a difficult time coming up with a definite answer. In any case, I would like to know what your findings were. Thanks.
Lonnie.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Questions on fixing Whirlpool gas dryer no heat problem yzhong Dryer Repair 0 08-02-2009 09:29 AM
Having problems with my dryer zora0623 Dryer Repair 1 07-24-2009 05:45 PM
dryer problems Nadsdad Dryer Repair 1 03-16-2008 09:52 AM
Dryer problems Charlie1076 Dryer Repair 1 01-16-2008 01:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
