Discuss
Motor running but drum does not turn
 in
Dryer Repair
Hi, I believe my problem is a broken belt but I can not find out how to open up the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Motor running but drum does not turn
  #1 (permalink)
Old 07-23-2009, 06:49 PM
Junior Member
chaz24 is on a distinguished road
Default Motor running but drum does not turn
Model Number: LEW0050PQ3   Brand: Whirlpool   Age: 1 - 5 years
I believe my problem is a broken belt but I can not find out how to open up the dryer. As you can probably tell by the model number but this is a dryer mounted on top of a washer.
All help is appreciated.
Thank you
Ads By Google
Related Models
Whirlpool LEW0050PQ3 Compact Electric Dryer
Whirlpool LEW8858HQ0
Whirlpool LEW8858HQ1
Whirlpool LFA3000W0
Whirlpool LFA3000W1
Whirlpool LFA3800W0
Whirlpool LFA3800W1
Whirlpool LFA3805W0
Whirlpool LFA3805W1
Whirlpool LFA4000W0
Whirlpool LFA4000W1
Whirlpool LFA5300W0
Whirlpool LFA5300W1
Whirlpool LFA5380W0
Whirlpool LFA5380W1
Whirlpool LFA5500W0
Whirlpool LFA5500W1
Whirlpool LFA5500W2
Whirlpool LFA5505W0
Whirlpool LFA5505W1
Whirlpool LFA5505W2
Whirlpool LFA5520W0
Whirlpool LFA5520W1
Whirlpool LFA5525W0
Whirlpool LFA5525W1
Whirlpool LFA5530W0
Whirlpool LFA5530W1
Whirlpool LFA5535W0
Whirlpool LFA5535W1
Whirlpool LFA5580W0
Whirlpool LFA5580W1
Whirlpool LFA5585W0
Whirlpool LFA5585W1
Whirlpool LFA5600W0
Whirlpool LFA5600W1
Whirlpool LFA5600W3
Whirlpool LFA5605W0
Whirlpool LFA5605W1
Whirlpool LFA5605W3
Whirlpool LFA5680W0
Whirlpool LFA5700W0
Whirlpool LFA5700W1
Whirlpool LFA5700W2
Whirlpool LFA5700W4
Whirlpool LFA5700W5
Whirlpool LFA5705W0
Whirlpool LFA5705W1
Whirlpool LFA5705W2
Whirlpool LFA5705W4
Whirlpool LFA5705W5
Whirlpool LFA5800W0
Whirlpool LFA5800W1
Whirlpool LFA5800W3
Whirlpool LFA5805W0
Whirlpool LFA5805W1
Whirlpool LFA5805W3
Whirlpool LFA6380W0
Whirlpool LFA6380W1
Whirlpool LFA6480W0
Whirlpool LFA6480W1
Whirlpool LFA6680W0
Whirlpool LFA6680W1
Whirlpool LFA6800W0
Whirlpool LFA6800W1
Whirlpool LFA6805W0
Whirlpool LFA6805W1
Whirlpool LFA6900W0
Whirlpool LFA6905W0
Whirlpool LFA7000W0
Whirlpool LFA7000W1
Whirlpool LFA7005W0
Whirlpool LFA7005W1
Whirlpool LFA7500W0
Whirlpool LFA7500W1
Whirlpool LFA7505W0
Whirlpool LFA7505W1
Whirlpool LFA7600W0
Whirlpool LFA7600W1
Whirlpool LFA7605W0
Whirlpool LFA7605W1
Whirlpool LFA7650W0
Whirlpool LFA7650W1
Whirlpool LFA7655W0
Whirlpool LFA7655W1
Whirlpool LFA7680W0
Whirlpool LFA7685W0
Whirlpool LFA7700W0
Whirlpool LFA7700W1
Whirlpool LFA7705W0
Whirlpool LFA7705W1
Whirlpool LFA7800W0
Whirlpool LFA7800W1
Whirlpool LFA7800W2
Whirlpool LFA7800W4
Whirlpool LFA7805W0
Whirlpool LFA7805W1
Whirlpool LFA7805W2
Whirlpool LFA7805W4
Whirlpool LFA7900W0
Whirlpool LFA7900W2
Whirlpool LFA9800W0
Whirlpool LFA9800W1
Whirlpool LFA9800W3
Whirlpool LFB2611LQ0
Whirlpool LFB2611LT0
Whirlpool LFB5150W0
Whirlpool LFB5150W3
Whirlpool LFB5300W0
Whirlpool LFB5300W3
Whirlpool LFB5300W4
Whirlpool LFB5500W0
Whirlpool LFB5500W1
Whirlpool LFB5500W3
Whirlpool LFB5500W4
Whirlpool LFB7700W0
Whirlpool LFB7700W3
Whirlpool LFB7750W0
Whirlpool LFB7750W3
Whirlpool LFC4500W0
Whirlpool LFC4500W1
  #2 (permalink)
Old 07-25-2009, 06:09 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Chaz
I am not familiar with that model, and I assume no one else who responds on this Forum is either since they have not responded.
I can tell you that in general a dryer is accessed from the front, with the top and the front coming off. You can now install the belt, with access to the tension pulley from the front or from a panel in the back.
Good luck, hope this helps
__________________
  #3 (permalink)
Old 08-03-2009, 07:29 PM
Junior Member
Default
Thanks very much for replying. I was able to remove the top after locating a illustrated parts list.
This particular model has two screws in the back that secure the cover. Once those are removed you tilt cover up and off. This model has the switch console in the front and not on top as you usually see them. This is because it is a compact dryer made to be placed on top of the washer. I believe it is assembled from the front to the back.
The belt appears to be intact although it is peeling and should be replaced. I believe you go thru the back and not the front with this model. The tub appears to be supported thru the back of the machine. There was cover to a drum shaft support on the back panel that I unscrewed. I would have to force it off and at that point I decided to come back to a help site such as this.
As I said the belt did not appear to be broken but was loose so perhaps it is an idler arm but I did not see one. There are two motors, one for the blower and another that I assume is to turn the drum.
Any help or advice greatly appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
drum wont turn while motor humms bobinski Dryer Repair 0 02-17-2010 09:06 PM
drum won't turn kgroat Washer Repair 3 12-14-2009 05:31 PM
Motor turn but not drum jpwlch Dryer Repair 1 12-11-2008 01:28 PM
motor hums but drum will not turn judy71635@alltel.net Dryer Repair 1 07-30-2008 08:28 PM
Drum won't turn Jeff52 Dryer Repair 7 02-05-2008 02:31 PM
