| » Dryer: No Heat: Troubleshooting Results |
Model Number: 90 series Brand: Kenmore Age: 5 - 10 years
Dryer has no heat. Got ohmmeter and checked continuity. High limit fuse checked ok, high limit thermostat checked ok, heating element checked ok, the cycling thermostat did not check out, so I replaced the thermostat with a new one, still did not check out....could it be wiring, or is there a chance that something other than the cycling thermostat is the culprit. I hate to keep spending money replacing the same part, if in fact, something else might be causing the problem.
Hi Jeff
Check to make sure you have 120 volts to each side on the connection block. If that checks out, check your thermal fuse. If you need more info please post your full model number and the results of the above. Thanks
__________________
| Display Modes | |
| Troubleshooting Kenmore micro hood w/no heat | Nottheaveragejoe | Microwave Repair | 5 | 03-20-2011 07:29 AM |
| dryer troubleshooting | seo | Dryer Repair | 1 | 08-02-2009 07:55 AM |
| dryer motor troubleshooting | patdoc | Dryer Repair | 5 | 07-23-2008 06:12 PM |
| Gas Dryer Troubleshooting | RICK 3 | Dryer Repair | 3 | 04-30-2008 03:18 AM |
| Whirlpool Gas Dryer Troubleshooting | Engram | Dryer Repair | 1 | 03-20-2008 06:41 PM |
