adaisy36
#1 Posted : Tuesday, February 14, 2012 7:33:00 AM(UTC)
adaisy36
i was drying clothes and the clothes were almost burning so i pulled them out i put another load in and they dryed fine the next load after that when i put them in the dryer would not turn and when i pushed the start button it just buzzed and shut right off...seemed like it was locked up. we checked the motor and it turns fine. we just dont know what the issue is. we do know the heating element is broken.
#2 Posted : Wednesday, February 15, 2012 4:29:28 AM(UTC)
Replacement parts for Frigidaire FEX831CS0 Frigidaire/laundry Center | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...1341356aelec_sheet_1.pdf
Turn the drum in the correct direction. It should turn fairly easily. If not you may have a mechanical problem that is putting too much load on the motor.
Unplug the unit
Remove both wires from the heating element and tape them so they cannot short to anything. use several wraps of electrical tape and also try to get them to where they are not touching anything.
The heating coil may be drawing juice and pulling down the voltage so the motor is not getting the correct 120 volts.
Alternatively you could check the power to the unit..
L1 to L2 should be 240 volts
If OK
If OK
Do this with the unit off and on.
If drum drag and power is OK try the following.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
Kenmore Dryer not turning on - hear timer clicking (Dryer Repair)
by Daibheid 6/16/2015 6:48:02 AM(UTC)
Dryer not turning on (Dryer Repair)
by rhschumaker 11/24/2013 11:31:38 AM(UTC)
Dryer Not Turning (Dryer Repair)
by TurnerHouse 3/5/2011 7:42:43 AM(UTC)
Whirlpool dryer not turning (Dryer Repair)
by madge 1/15/2011 6:43:49 AM(UTC)
kitchen aide dryer not turning on (Dryer Repair)
by dakota70 7/13/2010 12:23:39 PM(UTC)
Whirlpool Front Load Dryer Not Turning (Dryer Repair)
by MIKE@mikecolson.com 7/7/2010 10:35:36 AM(UTC)
GE dryer not turning w/ heavy loads (Dryer Repair)
by dmeiss 2/19/2010 4:51:24 AM(UTC)
by melissac 1/10/2010 3:02:36 PM(UTC)
Dryer Not Turning On (Dryer Repair)
by ANG1103 9/24/2009 2:37:49 PM(UTC)
whirlpool duet dryer not turning on-error code 3E (Dryer Repair)
by kmsewell 7/30/2009 8:22:35 AM(UTC)
Electric Dryer Not Turning, how to fix? (Dryer Repair)
by ksdc910 1/29/2009 10:24:16 AM(UTC)
Roper Dryer Not Turning On At All (Dryer Repair)
by 30tredog 9/23/2008 4:49:10 AM(UTC)
Dryer not turning (Dryer Repair)
by swtmama5 1/27/2008 8:18:05 AM(UTC)
