Discuss
kenmore series70
 in
Dryer Repair
HELP!!!! I recently moved the dryer from house back to the garage. Had no problems withit before, know every other
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore series70
  #1 (permalink)
Old 07-22-2009, 03:15 PM
Junior Member
ahelm75 is on a distinguished road
Default kenmore series70
Brand: -brand-   Age: Less than 1 year
HELP!!!! I recently moved the dryer from house back to the garage. Had no problems withit before, know every other load it trips half the braker so the heating element and timer stop working but the dryer still runs. Is this a dryer problem or braker? Washer room was moved indoors 2 yrs ago. prior to that never had problems with garage washers room.
Ads By Google
  #2 (permalink)
Old 07-24-2009, 07:43 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Ahelm
Replace the breaker, that will either fix the problem or allow you to rule out the breaker as a problem.
If the breaker is ok, you should still be under factory warranty if your machine is less than one year old.
If you still want to check it yourself, your next suspect a grounded or shorted heating element.
Good luck, and if you need more ifo please post the complete model number.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
