Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   kenmore series70 (http://forum.appliancepartspros.com/dryer-repair/41590-kenmore-series70.html)
ahelm75 07-22-2009 03:15 PM
kenmore series70
HELP!!!! I recently moved the dryer from house back to the garage. Had no problems withit before, know every other load it trips half the braker so the heating element and timer stop working but the dryer still runs. Is this a dryer problem or braker? Washer room was moved indoors 2 yrs ago. prior to that never had problems with garage washers room.
sidfink43 07-24-2009 07:43 AM
Hi Ahelm
Replace the breaker, that will either fix the problem or allow you to rule out the breaker as a problem.
If the breaker is ok, you should still be under factory warranty if your machine is less than one year old.
If you still want to check it yourself, your next suspect a grounded or shorted heating element.
Good luck, and if you need more ifo please post the complete model number.
