Dryer won't start. The start switch knob has cracked on the D-shaped female switch receiver and the start switch shaft has worn from the bad knob. It eventually quit turning the start switch shaft. I replaced the start switch and knob which now work perfectly but the dryer still doesn't start. I haven't put a meter on anything as I'm totally surprised that the replacement parts didn't fix the symptoms.
There's power as the light works when the door opens but there isn't as much as a click, bump or other indication of contact.
