Our Kenmore Elite gas dryer is no longer drying. Everything else is working except for the heat. I took the front lower panel off and started the dryer. I can see glowing shortly after turning it on but the glow slowly goes out, which I'm going to assume means a part needs to be replaced.
Any help would be greatly appreciated. Thanks in advance for any help!
Kevin
