Discuss
2003 Kenmore Dryer : Intermittent Heat
 in
Dryer Repair
Problem started today, where the heat is intermittent. I've found that when the unit has no clothes in it, the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » 2003 Kenmore Dryer : Intermittent Heat
  #1 (permalink)
Old 07-22-2009, 12:17 PM
Junior Member
jeffsuwanee is on a distinguished road
Default 2003 Kenmore Dryer : Intermittent Heat
Brand: Kenmore   Age: 5 - 10 years
Problem started today, where the heat is intermittent. I've found that when the unit has no clothes in it, the heat works fine. Once clothes are in, no heat. Also, no heat until the unit has a short period of down time between runs....heating element or thermostat?
Ads By Google
  #2 (permalink)
Old 07-24-2009, 07:22 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Jeff
Well this is a mystery, I mean the dryer is an inanimate object, it does not know if you have clothes in it or not.
I suspect the problem is a broken heating element (if you have an electric dryer) or problems with the gas burner system, coils, igniter etc (if you have a gas dryer). Get a meter and check continuity in your thermal fuses/thermostats, and if they check out check the heating system itself.
Good luck and if you need more info post your results and the full model number.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer intermittent heat rpuglia Dryer Repair 3 09-30-2009 01:33 PM
Dryer intermittent to no heat edm812 Dryer Repair 6 07-30-2009 07:03 PM
Intermittent dryer heat edm812 Dryer Repair 4 04-15-2009 06:08 AM
Kenmore Electric Dryer Intermittent Heat question bolingmike Dryer Repair 3 02-23-2009 06:28 PM
Kenmore dryer has intermittent heat acillatem Dryer Repair 5 12-22-2008 05:55 PM
