Discuss
dryer making load sqeaking sound
 in
Dryer Repair
our frigidaire dryer(def-w-4) or washer(wl-w-1) is making a load sqeaking sound wich sounds similiar
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer making load sqeaking sound
  #1 (permalink)
Old 01-07-2008, 11:00 AM
SPDYFM SPDYFM is offline
Junior Member
SPDYFM is on a distinguished road
Default dryer making load sqeaking sound
Model Number: Def-w-4   Brand: Frigidaire   Age: 5 - 10 years
our frigidaire dryer(def-w-4) or washer(wl-w-1) is making a load sqeaking sound wich sounds similiar to a car belt going bad is this something wich the average guy like me can fix? or is this another problem other than a belt.
frank
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 01:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Which appliance is making a wrong noise: the dryer or the washer?
In order to provide the most accurate advise I need the complete and valid model number of the unit.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 04-02-2008, 11:49 AM
jdlee jdlee is offline
Junior Member
jdlee is on a distinguished road
Default
I'm having the same problem. I have a Maytag DRYER mod. #LDE9314ACE, s/n 13889580MQ. How do you open the cabinet up?
  #4 (permalink)
Old 04-02-2008, 07:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove two screws on the bottom of the front panel.
Grab the front panel from the bottom and pull it forward and up to release it from the top fasteners. Remove the wires from the door switch (draw a picture for yourself to remember how to install them back) and put the front panel aside.
Remove the four screws holding the tumbler front assembly and check the drum support bearings (#8 on the tumbler parts break down diagram).
Remove the access cover on the back of the dryer. Draw a picture of the belt goes around the motor and the idler pulleys for proper assembling later. Remove the belt.
Remove the tumbler. Check the drum support rollers and the idler pulley. Lubricate them or replace if needed.
- The part number for the drum support bearing kit (rivets are included) is AP4037304
- The part number for the drum support roller is AP204721
- The part number for the idler pulley is AP3970789
- The part number for the belt is AP3988821
Here are the break down diagrams for the Maytag dryer Model LDE9314ACE
__________________
  #5 (permalink)
Old 04-04-2008, 01:23 PM
musicmanern musicmanern is offline
Junior Member
musicmanern is on a distinguished road
Default Squeaky Dryer
I had this problem once with a Kenmore dryer. It was the idler pulley that holds the tension on the drum drive belt. The pulley was worn out due to being dry for so long. I replaced the pulley and that corrected the problem. Also the drum support rollers may become noisy too either from wear or build-up of material on the surface of the rollers and the contact area on the drum. Cleaning of the rollers and the drum surface wil quiet down everything a lot.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer not cooling/making clicking sound momof1 Refrigerator & Freezer Repair 3 12-12-2007 02:36 PM
Dryer making horrible rattling sound when running wolverine666 Dryer Repair 0 09-23-2007 01:16 PM
Frezzer making a whistling sound and won't make ice nickysduck2 Refrigerator & Freezer Repair 1 09-12-2007 04:20 PM
Dryer makes a loud pinging sound Krwool Dryer Repair 2 08-21-2007 02:59 AM
Dryer makes rumbling sound when starts Scottnvegas Dryer Repair 3 08-12-2007 09:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
